  • Member For: 20y 1m 23d
undo all the bolts holding them in, then take them out!
I would say that you may wish to retain the sensor connected to the bottom of the seat (senses when you are sitting on it, and no seatbelt on). Just put the sensor under your seat - and it will think you are never sitting down. (otherwise you may get the annoying bong bong going on).
Edited by cobrav8
  • Member For: 22y 2m 2d
Just slide back the plastic bolt covers, and you need larger style star bolt driver?? the set is cheap at auto stores. careful of the wiring, needs to be unplugged first.
  • Great rack
  • Member For: 22y 1m 21d
A "T50, TORX bit" is the correct name and size.
  • Member For: 20y 3m 15d
There is a warning to wait atleast 1 minute after disconnecting the battery before disconnecting the supplimentary restraint connector. I guess this is the seatbelt pre tensioner. Or it could cause premature deployment and cause personal injury.
Someone else might know more about this I'm only going on what I have read.
