No More Drag Racing For Me
  • Moderating Team
  • Member For: 22y 3m 11d
  macka said:
How about getting a ute and putting all your goodies in that.
Get a super strong 9" diff, tub out the back and put some real big rubber under the arse end.    :kissmy: No CV joints to worry about then.
fit a larger turbo and try for an 8 sec  :spoton:
fastest ute as well a sedan in Australia.  :kissmy: has to be Whinter White of coarse  :spoton:
macka
<{POST_SNAPBACK}>
You could buy a Ute shell from Ford for 8K.
Tub it, 9in it, chuck your engine and driveline in, Motec to drive it all, easy peasy thanks for coming!
  • Replies 38
  • Member For: 20y 11m 15d
  xarh6turbo said:
  macka said:
Adam,
Get a super strong 9" diff, tub out the back and put some real big rubber under the arse end.    :pinch: No CV joints to worry about then.
fit a larger turbo and try for an 8 sec  :kissmy:
macka
<{POST_SNAPBACK}>
Funny you say that macka , that something we are looking at as we have a spare xr6 turbo ute
<{POST_SNAPBACK}>
Great minds think alike :spoton::kissmy:
Hopefully you will have a crack at it :kissmy:
It would be awesome to see someone really build something special and build a dedicated racer using the ute as the base and using Ford the turbocharged 6
Shortened 9" some big slicks, proper suspension in the arse to get all that grunt to the ground. :blush:
go on you know you want to
I know I would if I had the money
macka
The pump fuel record (street)is there for the taking, and will be a lot easier on your drivetrain.
  • Gold Platinum Member
  • Member For: 20y 10m 16d
Nooo we are loosing another hero :( As this car gets cheaper we are gona get more 'young foools' in here who a lot of are tools sadly...
  • Member For: 20y 1m 18d
How about building/buying a rail dragster and using your engine and transmission?
That would be really lightweight, be quicker than a heavy ute.
  • Team Bute
  • Member For: 21y 9m 27d
Unbolt the tray out of the ute, and you'll shed heaps of weight.
Make up a lightweight flat bed and you'll have the quickest and most unique Ford 6 commercial in the world!
How much does that rear ute tray weigh.... must be at least 300 kg I'd say.
Even if you shed 200kg, you'd strip at least half a second off your times :crybaby:
Go on.... the 8's are beckoning you!
Even if you shed 200kg, you'd strip at least half a second off your times :spoton:
<{POST_SNAPBACK}>
Exactly :msm: turn it into something that you can line up against APS LS1 one tonner and blow them away. :msm:
macka
