F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 9d Gender: Male Location: Strapped in and holding on Posted 01/10/05 09:52 AM Share Posted 01/10/05 09:52 AM How much boost was being run to get your rwkw figure??Power is not the killer, boost is.. I think this is why we see some variation in when engines' break..Hard call to put fomoco at fault though.. unlucky co-incidence perhaps.. Link to comment Share on other sites More sharing options...
Guest Guests Posted 01/10/05 12:35 PM Share Posted 01/10/05 12:35 PM near none of the above matters just get it independantly assessed as to me it sounds like either 1. the valve droped due to not being refitted corectly / collett not replaced etc2. the collett droped into the timing chain and caused a the marks and b the damage due to chain damage3. piston crown separation is a comon machined/casting fault although not normally on xr6t'sd&t are now apc yeah?if so ill be there soon tuning xr6t's for a few west aussies!!!! Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 9d Gender: Male Location: Strapped in and holding on Posted 01/10/05 02:06 PM Share Posted 01/10/05 02:06 PM Dynowog, wouldn't the bent valve be caused by the piston crown smacking it, cancelling out 1 & ( If the bent valve and busted piston came from the same bore ) And 3 being caused by the rod going east?? Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 9d Gender: Male Location: Strapped in and holding on Posted 01/10/05 02:08 PM Share Posted 01/10/05 02:08 PM if so ill be there soon tuning xr6t's for a few west aussies!!!!<{POST_SNAPBACK}>Give me a buzz, Might allocate a spare slot for a wog tune, can't hurt to have more to choose from!! Link to comment Share on other sites More sharing options...
Guest Guests Posted 02/10/05 08:58 AM Share Posted 02/10/05 08:58 AM Dynowog, wouldn't the bent valve be caused by the piston crown smacking it, cancelling out 1 & ( If the bent valve and busted piston came from the same bore ) And 3 being caused by the rod going east??<{POST_SNAPBACK}>all posibilities and I was tired posted it from envi t's place in bendigo!there are actually other posibilities!!! Link to comment Share on other sites More sharing options...
Guest Guests Posted 02/10/05 09:00 AM Share Posted 02/10/05 09:00 AM if so ill be there soon tuning xr6t's for a few west aussies!!!!<{POST_SNAPBACK}>Give me a buzz, Might allocate a spare slot for a wog tune, can't hurt to have more to choose from!!<{POST_SNAPBACK}>send me your number and I will or call me on 0422 452 007!!! Link to comment Share on other sites More sharing options...
cqae Member 229 Member For: 21y 2m 19d Posted 03/10/05 02:53 AM Share Posted 03/10/05 02:53 AM I know its a bit late, but I will add my 2 cents worth. A collet in the sump is very unlikely to cause drama. The oil pick up's strainer is a fairly coarse mesh, probably of similar size to the sort of stuff you might put up as shade for a pergola, but of course it is metal wire. So there is no chance of it picking up the collet. The collet is likely to suit harmlessly at the mottom of the sump. However, it depends on where they dropped it. If they dropped it down the front timing case cover that could do damage, most liely straight away, but it could sit somewhere & bounce of & drop into the chain area & do lotsa damage there.someting else to check, did they put another collet on? I know sounds stupid but if they only put one collet on top of the valve it might drop out under a lot of load. I think the most liely case is on valve not assemble properly & let go when u gave it a thrash, the problem is, how do you prove it? I know not alot new in this post, but it my opinion & I would lie to know how u go. Last of all, sorry to hear, always heartbreaking when your car goes bang. Link to comment Share on other sites More sharing options...
