AdamQball Member 11 Member For: 19y 7m 30d Posted 27/09/05 09:01 AM Share Posted 27/09/05 09:01 AM XXXR6T I know what u mean about not getting clear sound out of the rear speakers I just had 2 amps,sub and new speakers fitted and in the end they decided to run the whole system off the front because they couldnt get a clear sound out of the rear Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-298866 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 7d Gender: Male Location: OZ Posted 27/09/05 09:41 AM Share Posted 27/09/05 09:41 AM AdamQball, you may be onto something for XXXR6T and I. How would you describe the sound from the sub in comparison to the sound when run of an aftermarket head unit?? I might have to do the same. What speakers do you have in the front?? I have some pioneer splits which I might stick in the front and run them off another alpine I have. Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-298878 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 7m 22d Gender: Male Location: Perth, WA Posted 27/09/05 11:31 AM Share Posted 27/09/05 11:31 AM I would have done this but I was reluctant to do anything too permanent by cutting the front speaker wires and powering them from an amp... also that would mean I would need new speakersOne thing I just realised also is that the stock stereo has it's own sound processing circuits and clips out a lot of bass when you turn it up so it avoids distortion... I have noticed this without the sub attached, turning the stereo up quickly and you get a loud sound (pretty muddy one too) then it cuts the bass back to clean it up in the stock speakers. Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-298925 Share on other sites More sharing options...
AdamQball Member 11 Member For: 19y 7m 30d Posted 27/09/05 12:51 PM Share Posted 27/09/05 12:51 PM IH8PORK said: AdamQball, you may be onto something for XXXR6T and I. How would you describe the sound from the sub in comparison to the sound when run of an aftermarket head unit?? I might have to do the same. What speakers do you have in the front?? I have some pioneer splits which I might stick in the front and run them off another alpine I have.<{POST_SNAPBACK}>I still have the factory deck feeding 2 kicker amps 1 is 650w 4ch and the other is a 1450w mono amp for the 1500w kicker sub .Also had 2 sets of pioneer speakers fitted splits in front and 6/9s for the rear Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-298964 Share on other sites More sharing options...
bugster70 Donating Members 1,326 Member For: 19y 11m 13d Location: Canberra Posted 27/09/05 11:22 PM Share Posted 27/09/05 11:22 PM XXXR6T said: One thing I just realised also is that the stock stereo has it's own sound processing circuits and clips out a lot of bass when you turn it up so it avoids distortion...Can't you turn that function off? Haven't got my car handy, but from memory there is a screen in the menu that has CD compression and something else that sounds like what you're talking about, and I think both can be disabled. The manual says something about leaving them on to protect it from distorting, but I've switched both mine off - sounds much better like that. Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-299035 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 7m 22d Gender: Male Location: Perth, WA Posted 27/09/05 11:23 PM Share Posted 27/09/05 11:23 PM Hmm interesting... I shall investigate Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-299036 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 7d Gender: Male Location: OZ Posted 27/09/05 11:54 PM Share Posted 27/09/05 11:54 PM Alrighty, here are some pics of my line level setup, amp, subs and a few of the std amp and sub. I intend on mounting the alpine amp where the std amp is because it fits pretty good. However until im happy with the sound its just saying under the rubber boot liner. Looking at it last night didnt make it sound any better Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-299055 Share on other sites More sharing options...
nang3 12" member Donating Members 2,107 Member For: 19y 9m 22d Location: Perth WA Posted 28/09/05 12:51 AM Share Posted 28/09/05 12:51 AM XXXR6T said: I would have done this but I was reluctant to do anything too permanent by cutting the front speaker wires and powering them from an amp... also that would mean I would need new speakersOne thing I just realised also is that the stock stereo has it's own sound processing circuits and clips out a lot of bass when you turn it up so it avoids distortion... I have noticed this without the sub attached, turning the stereo up quickly and you get a loud sound (pretty muddy one too) then it cuts the bass back to clean it up in the stock speakers.yep that's exactly it, the stock headunit applies its own EQ processing to the signal before sending it to each speaker, that way the signal is effectively customised for each speakers frequency range etc..You can disable the CD compression limiting and all that, but I think that's for something different..The closest solution I have heard of is a new line level converter coming out in a month or so (cant remember the brand for the life of me) that once you hook it up, you play the reference disc that comes with it, and it effectively re-equalises the signal back to normal..... something like that anyway.. but its sposed to be around a grand, so you're almost better off buying a good HU and ignoring the factory stereo controls IMO ... Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-299073 Share on other sites More sharing options...
FAT-51X Member 254 Member For: 20y 11m 7d Gender: Male Location: Newcastle Posted 28/09/05 01:18 AM Share Posted 28/09/05 01:18 AM ok guys.. from all this I still cant understand what JB Hi Fi told me when they did the install on my XT..from what I gather there are a number of you who hav not got premium sound but are running aftermarket amps and subs and speakers....JB Hi Fi told me it is not possibkle for me to run rear speakers if I have the subs due to no rca's or something.. but it sounds like a few of u are running all 4 spekers plus subs with non premium sound (or maybe I just cant read)will I have to buy an aftermarket headunit in order to run 4 speakers or is there a way of achieving this without bridging my front splits???Cheers, Troy Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-299078 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 7d Gender: Male Location: OZ Posted 28/09/05 01:26 AM Share Posted 28/09/05 01:26 AM I have premium sound and run all 4 speakers and sub/amp but sound quality is not so good. The same goes for non premium sound falcons. Have a look at my photos of the speakers above. I have connected the line level converter to the rear speakers so that I can reconnect the speakers as well. Link to comment https://www.fordxr6turbo.com/forum/topic/20261-sub-woofer-installs-for-bas/page/4/#findComment-299079 Share on other sites More sharing options...
