wild4d Member 23 Member For: 19y 5m 15d Posted 19/09/05 06:49 AM Share Posted 19/09/05 06:49 AM what would be the best exhaust to fit to my xr6t (ute), I was thinking 3" from the turbo back with high flow cat. By the way I got the capa flash tuner - its a decent improvment in kw's for a $1000 Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 21y 8m 21d Location: Sydney Bronx :) Posted 19/09/05 07:38 AM Share Posted 19/09/05 07:38 AM Whats important is how much power are you currently running??I tested a 3" system, along with a bunch of others (for reference please look at http://www.bestmufflers.com/Information/Cu...yno_results.htm )and the max I could get out of the car was 270rwkw. I had to up the size of the exhaust to get more then that.RegzDean Link to comment Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 3m 6d Location: Eastern Suburbs of Mexico Posted 20/09/05 06:50 AM Share Posted 20/09/05 06:50 AM what would be the best exhaust to fit to my xr6t (ute), I was thinking 3" from the turbo back with high flow cat. By the way I got the capa flash tuner - its a decent improvment in kw's for a $1000Do A search, there is ALOT of information on what will suit your requirements. Be careful in modding your exhaust as you can and will go backwards in power. There are not many alternatives. XR6ISM has done alot of reasearch so search his threads they should also give you further indication. Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 21y 1m 3d Gender: Male Location: brisbane Posted 20/09/05 06:54 AM Share Posted 20/09/05 06:54 AM are you after an exhaust for better sound or for getting more power...If your not planning on modding your car to more then 280-300rwkw... then I would keep the stock exhaust (is a great system) and remove the centre muffler and replace it with a madrel bent section with hot dogs... sounds great Link to comment Share on other sites More sharing options...
PSISIX Member 42 Member For: 19y 11m 1d Location: perth Posted 21/09/05 12:20 AM Share Posted 21/09/05 12:20 AM not to hijack the thread or anything but what exhaust would be needed if your were chasing 400-450rwkw.... and to still keep it street legal...cheers Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 5m 24d Gender: Male Location: Mildura Posted 21/09/05 05:00 AM Share Posted 21/09/05 05:00 AM not to hijack the thread or anything but what exhaust would be needed if your were chasing 400-450rwkw.... and to still keep it street legal...cheers<{POST_SNAPBACK}>the APS system. Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 21y 8m 21d Location: Sydney Bronx :) Posted 21/09/05 05:30 AM Share Posted 21/09/05 05:30 AM My system with an added rear muffler (to keep it legal)http://www.bestmufflers.com/Information/Cu...yno_results.htm Link to comment Share on other sites More sharing options...
PSISIX Member 42 Member For: 19y 11m 1d Location: perth Posted 21/09/05 06:03 AM Share Posted 21/09/05 06:03 AM if I was to do 4inch dump pipe and cat into 4 inch pipe to centre muffler then 3 1/2 and then split it into twin pipes so I have the quad on each side... will having the quad pipes effect performance cause many people I have spoken to said it does?? Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 21y 8m 21d Location: Sydney Bronx :) Posted 21/09/05 03:38 PM Share Posted 21/09/05 03:38 PM if I was to do 4inch dump pipe and cat into 4 inch pipe to centre muffler then 3 1/2 and then split it into twin pipes so I have the quad on each side... will having the quad pipes effect performance cause many people I have spoken to said it does??<{POST_SNAPBACK}>As long as its done properly, and the bends aren't too sharp there shouldnt be a problem. Also depends on the welds, normally you would want an exhaust tig welded from the inside rather then mig from the outside. This stops spatter etc to get caught inside the system. There are all small things though, the easy answer to the question is no, it wont effect it (PS, also depends on the pipe sizes when you break off etc) Link to comment Share on other sites More sharing options...
