Guest fetish Guests Posted 18/09/05 03:43 AM Share Posted 18/09/05 03:43 AM Ive noticed that people who have installed aftermarket head units such as screens have installed them below the standard stereo and climate control in front of the gear stick.is it possible to remove the standard stereo and fit an after market unit in its place? if the plastic trimming can come off easily and is not attached to the stereo or fan/temp controls then fibreglassing a custom centre console isnt a huge problem. it could be made to fit in lace of the original item leaving a standard din size whole to fit a new deck? does anyone know if this is possible or is every attached as one whole unit?? Link to comment Share on other sites More sharing options...
xr6 typhoon Good for nothing member Donating Members 619 Member For: 20y 5m 9d Location: Sydney Posted 18/09/05 04:22 AM Share Posted 18/09/05 04:22 AM you remove the standard headunit you loose your climate control with your premium sound Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 10m 3d Gender: Male Location: brisbane Posted 18/09/05 04:56 AM Share Posted 18/09/05 04:56 AM I would also imagine that your ecu would have a spac attack Link to comment Share on other sites More sharing options...
God666 Complete Bastard Donating Members 1,123 Member For: 21y Gender: Male Location: Sydney Posted 18/09/05 05:10 AM Share Posted 18/09/05 05:10 AM I have found that the easiest way to remove your stereo is to leave your car parked in Redfern for about 20 mins (doors locked or not, it doesn't seem to matter).I do not have a solution for getting another refitted though!Nothing useful to add....... Link to comment Share on other sites More sharing options...
Guest fetish Guests Posted 18/09/05 06:08 AM Share Posted 18/09/05 06:08 AM if its the non premium sound model, is it a seperate unit? surely removing the stereo wont effect the ECU Link to comment Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 21y 10m 5d Gender: Male Location: Melbourne Posted 18/09/05 07:17 AM Share Posted 18/09/05 07:17 AM It's all a part of the body control module that is mated to the PCM and is an integral part of the car. Link to comment Share on other sites More sharing options...
rushed6 Member 137 Member For: 19y 3m 11d Gender: Male Location: Victoria Posted 18/09/05 07:48 AM Share Posted 18/09/05 07:48 AM if its the non premium sound model, is it a seperate unit? surely removing the stereo wont effect the ECU<{POST_SNAPBACK}>you dont belive him try it and report back to us Link to comment Share on other sites More sharing options...
Guest fetish Guests Posted 18/09/05 08:24 AM Share Posted 18/09/05 08:24 AM nah that's ok, I'll take his word for it. does the factory system have RCA outputs for amps? Link to comment Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 21y 10m 5d Gender: Male Location: Melbourne Posted 18/09/05 08:28 AM Share Posted 18/09/05 08:28 AM RCA Output, don't be silly, that would have been making life too easy for the customer.If you want to run external amps you will need to use the high level inputs from the speaker cables and then run your speakers and subs from your amp. Link to comment Share on other sites More sharing options...
rushed6 Member 137 Member For: 19y 3m 11d Gender: Male Location: Victoria Posted 18/09/05 08:33 AM Share Posted 18/09/05 08:33 AM RCA Output, don't be silly, that would have been making life too easy for the customer.If you want to run external amps you will need to use the high level inputs from the speaker cables and then run your speakers and subs from your amp.<{POST_SNAPBACK}>yeah that's what I did I got a ute just spliced into the rear speakers then hooked the low level input into it and then run the rca's to your amp then amp to sub easy as even someone at auto barn will know what your talking about Link to comment Share on other sites More sharing options...
