Barra 240 Member 5 Member For: 19y 8m 16d Location: Rockhampton Posted 30/08/05 11:46 AM Share Posted 30/08/05 11:46 AM Hey, Having owned a MrkII Xr6 Turbo now for several months, just wondering if you were able to upload the F6 Typhoon programing onto the XR6T. Just to give it more boost, and to give it better boost timing. Would you have to change the injectors at all, seeing as the standard injectors are aparently running at their limits? Or would it be cheaper just to go for a full ECU ungrade? Cheers, Kezza! Link to comment https://www.fordxr6turbo.com/forum/topic/19762-uploading-programming-ecu/ Share on other sites More sharing options...
AWW XR6T UTE Member 129 Member For: 22y 10d Location: Brisbane Posted 30/08/05 01:24 PM Share Posted 30/08/05 01:24 PM Boy have you got some reading to do!For the Typhoon option, see the following topic,http://www.fordxr6turbo.com/forum/index.ph...topic=19583&hl=The other easy option is to go for the edit, with 8-10 psi tunes, which should give you between 230-260 rear wheel KW, that is without changing anything else. The other simple mods are a second air intake & replacing the centre muffler (mainly for better sound!).If you have an auto, a transmission cooler is also a good idea.There has been a lot of 'discussion' about injectors, but for these mods the standard injectors seem to be fine, if you want more power then an injector change will be required.But be warned, if you start modifying, you might never stop, need more power, need more power,.......... Aaron. Link to comment https://www.fordxr6turbo.com/forum/topic/19762-uploading-programming-ecu/#findComment-288987 Share on other sites More sharing options...
Barra 240 Member 5 Member For: 19y 8m 16d Location: Rockhampton Posted 31/08/05 04:22 AM Author Share Posted 31/08/05 04:22 AM I am only a newby to this site but thanks for the reply. I will look into it more now. Which brand of hotdogs, would you suggest to ge the beefiest sound out of my XR? Any suggestions? The only mods I have done so far is the SS inductions Cold Air Intake, and a K & N high flow air filter. But am hopefully in the near future going to do more! Thanks!Kezza. Link to comment https://www.fordxr6turbo.com/forum/topic/19762-uploading-programming-ecu/#findComment-289082 Share on other sites More sharing options...
