Trough Lolly Member 4,349 Member For: 20y 4m 5d Gender: Male Location: Mildura Posted 22/08/05 08:36 AM Share Posted 22/08/05 08:36 AM try mods and garage mate Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 11m 12d Gender: Male Location: brisbane Posted 22/08/05 08:44 AM Share Posted 22/08/05 08:44 AM I changed mine to a 3" single s/s system with a hi-flow cat and definately noticed the difference in the low - mid range without having a retune (customed edit). no retune??Yes but not before bigger injectors were fitted at the same time so no way of knowing what if any rwkw increase there was.wouldnt you need a retune after the injectors getting fitted?? Link to comment Share on other sites More sharing options...
dutchie Member 391 Member For: 20y 9m 5d Location: Somewhere Posted 22/08/05 11:38 AM Share Posted 22/08/05 11:38 AM Just out of curiosity Jordak, did you do before and after dyno runs when you replaced your exhaust?CheersSteve<{POST_SNAPBACK}>Hi Vibe Ute........I actually did before going the Edit.........First I removed the Centre Muffler and replaced it with Dual 2 1/2" S/Steel pipes and hotdogs as well as MagnaFlow dual 2 1/2" S/Steel tips......Before this fitting I got 162RWKW's........I know this is low. but this was from a dyno that's renowned to be approx 20RWKS's lower then everyone elses.....Then after the fitting and replacing the filter with a BMC as well, the dyno got 181RWKW's.......Then once the CAPA was installed, I got 242RWKS.....(that's around 250-250RWKW's)Hope this helps........ Link to comment Share on other sites More sharing options...
vibe ute Member 158 Member For: 19y 5m 21d Posted 22/08/05 12:04 PM Share Posted 22/08/05 12:04 PM Thanks Dutchie, 19kW is a good gain from those mods.Cheers Link to comment Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 7m 4d Posted 23/08/05 06:41 AM Share Posted 23/08/05 06:41 AM <{POST_SNAPBACK}>I changed mine to a 3" single s/s system with a hi-flow cat and definately noticed the difference in the low - mid range without having a retune (customed edit). <{POST_SNAPBACK}>no retune??Yes but not before bigger injectors were fitted at the same time so no way of knowing what if any rwkw increase there was.wouldnt you need a retune after the injectors getting fitted??<{POST_SNAPBACK}>Had the custom edit for a while before I fitted the exhaust and held off getting a re-tune until I had the injectors fitted shortly thereafter. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 6m 21d Gender: Male Posted 23/08/05 06:59 AM Share Posted 23/08/05 06:59 AM http://www.fordxr6turbo.com/forum/index.ph...ndpost&p=279095bains post with movies!! Link to comment Share on other sites More sharing options...
