New Exhaust
Addy
  • fordxr5turbodotcom
  • Member For: 21y 3m 3d
Welcome!
There is a lot of discussion about exhausts on here.. hit the search area and go digging!
That said, it all depends on what you're after.... exhaust ISN'T the first thing to do if you're chasing more power... but if you want a nicer sounding note then removing the centre muffler is a cheap idea, it doesn't really add or reduce performance... just a bit more noise... I like it and would recommend it (as would many others).
Normally if you're chasing power then a Capa Edit + Injectors is the status quo these days and will give you around 300kws (at the fly) depending on the tuner...
Lots of info and good ppl on here so welcome and enjoy your T! :thumbsup:
  • Member For: 19y 5m 21d
Hi Addy,
welcome to the forum, I too am a newbie and have learn't heaps since being here. From what I've read the standard exhaust is okay up to about 300rwkw and about 350rwkw with a high flow cat. So unless your after very high power figures or more noise/better exhaust note, there's not much point replacing the exhaust.
Cheers
Steve
  • Member For: 20y 7m 4d
Hi Addy,
Cheers
Steve
<{POST_SNAPBACK}>
Regardless of whether the stock exhaust can handle 300+rwkw or not there is still some benefit in changing to a more free flowing exhaust (primarily the cat ) aside from the noise.
I changed mine to a 3" single s/s system with a hi-flow cat and definately noticed the difference in the low - mid range without having a retune (customed edit). A more free-flowing exhaust also takes a bit of pressure off your valve springs by all accounts.
.......oh and if I drop something whilst getting out of the car I get to look at my shiny exhaust :thumbsup:
Just out of curiosity Jordak, did you do before and after dyno runs when you replaced your exhaust?
Cheers
Steve
<{POST_SNAPBACK}>
Yes but not before bigger injectors were fitted at the same time so no way of knowing what if any rwkw increase there was.
I can tell you that seat of the pants low -mid range was noticable which means more to me than what the dyno spits out anyway.
The best way to expalin the difference was that a couple of times I thought the auto had kicked back to 3rd when giving it a bit of throttle in 4th only to find it hadn't. It just felt more lively and eager to wind up if that makes sense. :stirthepot:
  • Member For: 20y 4m 5d
no need for bigger exhaust on a T unless going over 330+ at the wheels.
doing your cat at around 280+ atw is a good idea though. I just got this today:
its a "metal-cat" from option1 garage in brisbane. their imported from the states and I believe one of the best cats to use on a xr6t.
  • THE Member
  • Member For: 19y 6m 8d
Hey Guys,
I think I read a thread a couple of weeks ago that had sound files of exhaust upgrades members had done, I have tried the search option but I cant find anything :tease:
Am I imagining it or can some one point me in the right direction? :stirthepot:
Cheers,
Brett
