  • Replies 161
  • 570Nm @1800rpm
  • Member For: 21y 8m 1d
The Turbo will go up to 245kw and 480Nm, which is a nice jump in torque! The close ratio 6 speed auto will be a $1500-$1800 option for the T.
Nice :laughing:
  • Member For: 21y 2m 21d
And what all you guys have been waiting for....
"Ford counts the addition of dual independent
variable camshaft timing and dual knock sensors
as the biggest change to the 4.0-litre six
The dual independent VCT is claimed to
deliver better low-speed torque, while the six
also now has a lower idle speed of 550rpm (down
from 700rpm)."
  • Just because it is, doesn't mean it should be.....
  • Member For: 20y 8m 11d
  • Gender: Female
Looking forward to more pics!
will reserve opinion till more is revealed
but for now... not sure about that front bar, looks very close to the
hyundai set up :laughing:
other spec's sound good
Shazzy
  • Member For: 20y 8m 12d
I'm very pleased to say the least that the 6 speed auto's made it in to most models. :laughing::pooh:
There's one more item of information that I am keen to find out and that is the final drive ratio, used on the auto's. I hope Ford don't use too higher gearing (low numerical value) in the bloody stupid quest for fuel economy only. :pooh:
I like performance and that means low gearing. 1st Gear in the ZF is about 4.12:1, but if Ford opt for something silly, like a 2.5:1 final drive then all the performance benefits of the close ratio 6 speed auto are lost.
Ahh well, I suppose, it will be pretty easy to swap to a lower diff gearset from the manual models, if they have. :sick::pooh:
Guest Mal
  • Guests
Barra 245T
4.0-litre DOHC I6 Turbo
245 kW @ 5250 rpm
480 Nm @ 2000 rpm
ZF 6HP26 six-speed auto
1st gear ratio 4.17
2nd gear ratio 2.34
3rd gear ratio 1.52
4th gear ratio 1.14
5th gear ratio 0.87
6th gear ratio 0.69
Reverse 3.40
Final Drive
Barra 245T / Boss 260: 2.73
BF XR6 & XR6 Turbo
New sports front bumper
New tail lamps
New 17" alloy wheel
New optional 18" alloy wheel
New six-speed automatic transmission.
The 6 six speed manual Tremec T56 gearbox, is only available on XR6T and XR8 models.
New soft-feel door grab handles with satin chrome inserts
New Liquid Metal finish on Interior Command Centre fascia, centre console and rear air vent register
New seat fabrics and trim inserts
New paint colours: Toxic, Bionic, Fantasy and Déjà Vu
Edited by Mal
  • Member For: 20y 20d
Anyone seen pics of the new BF from the rear? What do these new tail lamps look like? Without knowing much about it, it does sound (at this stage) like the changes are fairly minor? :nyyaah:
