  • Member For: 21y 7m 3d
  • Gender: Not Telling
went to ttf in dandy today and was told that SSL's for the back are illegal..
WHAT THE *beep*?? is this true??
  • Replies 37
Posted Images
  • Here since the start...
  • Member For: 22y 1m 15d
King Spring's say...
  Quote
Kings Super Low Sports Replacement Coil Spring Range is designed primarily for cosmetic enhancement (show cars etc). These parts may therefore render your vehicle illegal for use on public roads.
You would have to get it measured up to know for sure.
  • Member For: 20y 3m 12d
I cant see how they would be illegal.. (Lowest point on my car is 11cm's)
I had to cut my rear bump stops by about 20mm as they were sitting on them. The car dropped another 5 - 10mm since doing it.
ive got 19x9.5's on the back. they come flush with the side of the car..
if I put SSL's on it, would the tyre rub with the black plastic behind the wheel arch?
  • Member For: 20y 3m 16d
  Swanga said:
Just in case you havnt seen enough white Turbos with the same springs, heres mine after a couple of days...
<{POST_SNAPBACK}>
Had another good look at my car, looks like the pics you have posted in ride height. It might just be me expecting it to sit lower.
  • Benzene
  • Member For: 21y 6d
Its funny it looks lower in some positions then others, I would of liked for it to be a bit lower and hope it sags a little. Hopefully when I put some 19's on it it will fill it out a bit more.
  • Member For: 21y 8m 24d
Yep got the KING SSL on the back and SL on the front Have had them pn for more than a year am very happy with the looks. Yes they do settle after a few weeks. You will be happy like the rest that have gone that way.
