Noisy Front End
RHR
  • BOOST
  • Moderating Team
  • Member For: 21y 7m 5d
hey
Dropped my Turbo off today for some warranty work. One of the problems that I was having with the car was a "creeking" noise in the front end. One of the ford " trained tecnitions" advised me that this was not a warrany thing but in fact was a maintenance thing and of course they would charge me to fix it. Wouldnt you think that a car that has 18,000 on the clock would not have this problem and if a such problem did exist that they would fix it...
What are your thoughts??
revheadrobbo
  • Mushroom
  • Member For: 20y 10m 26d
hey
revheadrobbo
Total BS!!!!
A lot of blokes have had heat shield rattles fixed under warranty (including myself) and I've also had a dodgy engine mount fixed under warranty.
Try another dealer.
  • Member For: 20y 5m 29d
I have the same problem and will be taking it in to get fixed soon. I thought it was something to do with the shimming of the steering rack.
Let me know how you go. Is it Dominelli's that you took it to? that's where I take mine so I hope I don't encounter the same problem! If they try to make me pay for anything I'll tell them where to jam it! :blink:
Chris :nono:
  • Member For: 20y 1m 15d
goobz your correct about the shimming. they install some washers somewhere I think. mine made the noise when I drove out of the dealer on day 1. it was fixed the week after.
revheadrobbo, take it somewhere else, its a very common fault.
  • The 'nice guy'
  • Member For: 20y 7d
hey
revheadrobbo
Should look at tightening crossmember bolts, low speed turns like parking <bump, creak>.
Non warranty - what a load of. :k24t:
  • BOOST
  • Moderating Team
Yeah they reckon they need to retension some bolts in the front end and give her a lube. Of course I suspected they were taking me for a ride so I told them no
For all those Sutho people it was Domineli so if you still want to take it there note down your kms. I had a brake shudder problem also and it appeared thay they gave the car a flogging. When I dropped it off the car was well over 3/4 full of fuel. when I got it back I found it well under the 3/4 fill mark and there was a :stirthepot: load of brake dust on the rims. Kinda spewing I didnt note down the k's.
  • Member For: 20y 5m 26d
that's crap, I take the ute to pedders before every service just for a check up and they assure me nothing should go wrong with suspension for along time.
  • BOOST
  • Moderating Team
Pedders hey....
Dont they do that 14pt steering and suspension check for around 20 bucks
  • Member For: 21y 7m 7d
revheadrobbo
on your invoice does it list this
Suspension noise - TSB 90/04 Step.1 - Warranty
as the fix for the front end creeking noise? Do u get the noise while going over speed bumps or undulating road?
