2fardown Member 526 Member For: 19y 8m 9d Gender: Male Location: Brisbane Posted 21/07/05 12:07 AM Share Posted 21/07/05 12:07 AM Will these high flowed stock injectors work OK without an edit? Reason being if I decide to take off the edit I want to know if these injectors will work and the car will behave normally. Link to comment Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 2m 13d Location: In The Ute Posted 21/07/05 12:18 AM Share Posted 21/07/05 12:18 AM Will these high flowed stock injectors work OK without an edit? Reason being if I decide to take off the edit I want to know if these injectors will work and the car will behave normally.<{POST_SNAPBACK}>You can edit a map to suit any injector you like but the factory Ford map only knows the STD injector and as such will only run with the STD injectors in!!!The idea of the EDIT is to key in the new injector size and allow the Ford PCM to manage them with its algorithms and self learning to match the rest of the powertrain.So to answer your question these bigger injectors will not work with Factory map.It will idle but when you put your boot in it it will overfuel to the max. Link to comment Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 20y 6m 26d Gender: Male Location: Victoria Posted 02/08/05 05:18 AM Share Posted 02/08/05 05:18 AM I have Eugenes injectors... They are apparantly the same specs as the 969s. Link to comment Share on other sites More sharing options...
