JZ 97 SS 1500 Member 25 Member For: 20y 3m 9d Posted 23/07/05 04:21 PM Author Share Posted 23/07/05 04:21 PM BTW, here is his promo video....Right click and save as....JZ Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 8m 8d Location: Mildura Posted 23/07/05 05:21 PM Share Posted 23/07/05 05:21 PM Hi JZ,I know a bloke that had a complete Barra engine non turbo. He only wanted $2600 (Aus) as far as I know he still has it. Only travelled 3000km. Don't know how much it would cost to ship to the US though. If you interested I can find out if he still has it. macka Link to comment Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 19y 10m 11d Gender: Male Location: New Zealand Posted 24/07/05 11:13 PM Share Posted 24/07/05 11:13 PM Maybe you should import a complete car - and modify the whole lot - would make for an interesting beast in America. Link to comment Share on other sites More sharing options...
JZ 97 SS 1500 Member 25 Member For: 20y 3m 9d Posted 25/07/05 08:53 PM Author Share Posted 25/07/05 08:53 PM We are looking for a turbo engine right now only. As for importing a car...well that would be very expensive indeed. Right now we are talking with Ford USA and seeing what they can do to help us.JZ Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 8m 8d Location: Mildura Posted 25/07/05 11:03 PM Share Posted 25/07/05 11:03 PM I thought that the Turbo and N/A engine were exactly the same only lower compresion. Seeing as though you going to completely rebuild the engine whats the difference.I can only think of one possibility I know the turbo engine has a girdle but I'm not sure about the N/A engine other than that they are identical. Maybe some Ford workers can confirm. Considering you pay approx $1800 for a short motor I would have thought $2500 incl PCM was a pretty good price for a complete engine.good luck with your hunting look forward to seeing your resultsmacka Link to comment Share on other sites More sharing options...
JZ 97 SS 1500 Member 25 Member For: 20y 3m 9d Posted 26/07/05 02:28 AM Author Share Posted 26/07/05 02:28 AM Is the N/A motor the same except for compression?? Is the compression difference just due to piston difference?? Also does the N/A motor have piston squirters or does the Xr6 motor even have those. Also is the head the same and intake??? If they were all indeed the same then I would be interested.JZ Link to comment Share on other sites More sharing options...
Lawsy Wanabe mechanical engineer Donating Members 960 Member For: 20y 4m 18d Gender: Male Location: At the computer, obviously..... Posted 26/07/05 06:24 AM Share Posted 26/07/05 06:24 AM Is the N/A motor the same except for compression?? Is the compression difference just due to piston difference?? Also does the N/A motor have piston squirters or does the Xr6 motor even have those. Also is the head the same and intake??? If they were all indeed the same then I would be interested.JZI think the short blocks are almost identicle, but the long block would have all the differences... So a short block of either engine will give you everything you need and everything you don't need. Link to comment Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 21y 9m 9d Location: Geelong Victoria Posted 26/07/05 08:08 AM Share Posted 26/07/05 08:08 AM Is the N/A motor the same except for compression?? Is the compression difference just due to piston difference?? Also does the N/A motor have piston squirters or does the Xr6 motor even have those. Also is the head the same and intake??? If they were all indeed the same then I would be interested.JZ<{POST_SNAPBACK}>Pistons, conrods are slightly different, both have oil squirters. Head is same casting but valves are stainless in turbo. Lower intake assembly is very similar bar the variable intake butterflies aren't used in the turbo as they aren't needed, and different fuel regulator on fuel rail. Upper inlet manifold has different MAP sensor. Only slight differences between them, most of the stuff you would junk anyway such as rods and pistons. Link to comment Share on other sites More sharing options...
mickq Member 740 Member For: 21y 9m 13d Posted 26/07/05 12:27 PM Share Posted 26/07/05 12:27 PM His car is running a PTE 101 Thumper series. From 91.5 to 106mm they are all the same outer physical size.Here is another picture which is more up close....enjoy.....<div class='bbimg'><div class='bbimg'></div></div>...<{POST_SNAPBACK}>Thanks for the video.that's just like my car....only five times more powerful.... Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 20d Gender: Male Location: Strapped in and holding on Posted 26/07/05 12:51 PM Share Posted 26/07/05 12:51 PM Insane, I like your style... I take it with our road cars weighing in at 3900Lb's and set to run a 9 shortly, you will have no dramas running 7's with ~40% more power.. Can you post a picture of the shell you plan on using?? I take it I'm like most ppl here and have no idea what a 'fox' looks like.. What does it weigh?? Cheers, and good luck.. btw, does your Talon run the 4G63, and why are you running such a small snail on it???? what times have you got out of it?? nice little powerplant Link to comment Share on other sites More sharing options...
