RCTXR6T Member 4 Member For: 21y 2m 19d Posted 11/07/05 11:14 AM Share Posted 11/07/05 11:14 AM Hi everyone. I am only new this whole posting thing so here goes. I am in the process of installing an Xbox to my ride. Attached is a picture of the ICC. As you can tell I cannot get the sync to work. Does anyone have any thoughts on the matter? I have tried just about everything I can think of. I dont know if its correct but the Xbox is running NTSC RGB outputs into the ICC but know matter what sync wires I connect (either V Sync or H Sync) I cannot get any better than this. The box itself is running NTSC 4:3 - Is this correct?Any assistance will be greatly appreciated.Dave. Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/ Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 9m 2d Gender: Male Location: Mildura Posted 11/07/05 11:43 AM Share Posted 11/07/05 11:43 AM check out the post "digital tv for ford ICC" you might hafta do a search to find it but im sure it will have all the answers youll need to get you on the right track.goodluck. Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-271790 Share on other sites More sharing options...
RCTXR6T Member 4 Member For: 21y 2m 19d Posted 11/07/05 11:55 AM Author Share Posted 11/07/05 11:55 AM I have gone through the whole Doco but to no joy. I think my problem is getting the Xbox to run 16:9 not 4:3. I will have to find out how to change the video settings in more detail. Currently I only know how to go from NTSC M, NTSC J and PAL.Oh well making progress slowly I think! Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-271798 Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 9m 7d Location: Canberra - ACT Posted 12/07/05 06:01 AM Share Posted 12/07/05 06:01 AM Have you really set your xbox to NTSC mode? You can't can't make that change in the dash - you need to do it with a firmware switcher (Enigmah for example)... Actually having a go later this week on doing it to an un-modded box to get a legal setup...The pic you're showing is of PAL trying to be displayed ... Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-272010 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 11m 19d Gender: Male Posted 12/07/05 06:04 AM Share Posted 12/07/05 06:04 AM to change the box to 16:9 you have to go into the original dashboard and select it in the settings menu..good luck mate Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-272013 Share on other sites More sharing options...
RCTXR6T Member 4 Member For: 21y 2m 19d Posted 12/07/05 09:59 AM Author Share Posted 12/07/05 09:59 AM Unfortunately I wish it was the case, but I can confirm that it is running NTSC as I did use enigma option "B". I have also gone into the original dash and changed to wide screen. Hopefully this info might be of assistance to some one in the know!On the XBox A/V plug I have removed the original wiring harness and installed the follow connections. Pin 1 = Audio rightPin 2 = Audio right GroundPin 3 = Not used ( Digital Audio)Pin 4 = V-Sync (Does not seem to assist)Pin 5 = Mode GND for Pin 17Pin 6 = Mode GND for Pin 18Pin 7 = Mode GND for Pin 19Pin 8 = GroundPin 9 = Variable (Blue)Pin 10 = Pin 9 GroundPin 11 = Variable (green)Pin12 = Pin 11 GroundPin 13 = Not Used (VCC)Pin 14 = Audio LeftPin 15 = Audio left GroundPin 16 = H-Sync (Does not seem to assist)Pin 17 = Mode Select 1Pin 18 = Mode Select 2Pin 19 = Mode Select 3Pin 20 = Not Used (12volts output) Will be used once everything else is sorted.Pin 21 = Pin 22 GroundPin 22 = Variable (Red)Pin 23 = Pin 24 GroundPin 24 = Variable (Composite video signal)Please note that if pin 5 is linked to 17, 6 is linked to 18 and 7 is linked to 19 then the Xbox will output RGB Scart type outputs. This is how my XBox to ICC cable is made. If you read the Doco on Digital TV it tells you what connections to make at the ICC. The problem I have is working out the Sync wires.At this stage I believe the problem lies within the Xbox settings and not the cable I have made.Any assistance would be greatly appreciated.Hopefully this addition information will assist others in there design of cabling. Or it might just confuse the matter even more.Thanks for your time. I shall leave it at that as its long enough already.Dave. Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-272091 Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 9m 7d Location: Canberra - ACT Posted 13/07/05 02:17 AM Share Posted 13/07/05 02:17 AM ahhhh.... My suggestion would be to use a xbox RGB cable and hack the SCART off the end This is what I've done with no problems. Inside the SCART end there is a resistor etc to trigger the Pin8? (SCART) detection of the device and all that which I've left off.... Use the composite signal line (Pin 24) to get your combined Sync from... There's definately better pinout guides around that the one you've got there. but in the end (becuase they spent way to much time disagreeing with each other) I sent into the SCART end of the deal A. Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-272279 Share on other sites More sharing options...
RCTXR6T Member 4 Member For: 21y 2m 19d Posted 13/07/05 11:14 PM Author Share Posted 13/07/05 11:14 PM Well I'm Happy to announce that the whole project is now up and running. Firstly I woiuld like to thank AaronMihe and Shane XR6T for there assistance/suggestions along the way. It is now time to do all the installation work instead of the numerous trial runs. At this stage I still have to build my own auto switcher for audio and display when Xbox is turned on (Piece of cake). Also building a regulated power supply for the Xbox to run on 12volts.(not quite as easy as the auto switcher). Once all is in I will post some pics for others to see and not give up hope. Once again thanks Aaron and Shane and everyone that has made posts on this topic. From all the little bits and pieces you pick up it has helped quite a lot. All the information you need is out there all you have to do is spend some time looking for it. Dave. Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-272520 Share on other sites More sharing options...
Mitchy_G Umm... Member 176 Member For: 22y 17d Location: North Lake Macquarie NSW Posted 18/07/05 10:51 PM Share Posted 18/07/05 10:51 PM I purchased my xbox a few days ao and immediatley have the mod chip on the way!! ill try and keep this thread up to date with what im up to!Thanks everyone for their helpMitch Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-273888 Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 9m 7d Location: Canberra - ACT Posted 20/07/05 06:00 AM Share Posted 20/07/05 06:00 AM I have a brand new UNMODIFIED (ie Legal) Xbox that outputs NTSC here. It is possible to set a xbox to NTSC output without opening the case and installing a modchip. The box then functions exactly like a stocker...It's for sale as I don't need 3 xboxes (it was a raffle prize from the local club).A. Link to comment https://www.fordxr6turbo.com/forum/topic/18765-xbox-to-icc-help-please/#findComment-274364 Share on other sites More sharing options...
