Mals BA XR6T Member 381 Member For: 22y 4m 12d Location: Sydney Posted 25/06/05 07:55 AM Share Posted 25/06/05 07:55 AM I've just had a few things done, what are your thoughts...XR6T Auto1. Standard 186rwkW (5-6 PSI)2. Edit + Centre Muffler Removed + 2nd CAI 201rwkW (8PSI Map)3. X-Force 3" Exhaust + Injector Mod (high flow) + K&N Air Filter + 2nd CAI + Custom Tune 340rwhp (~250rwkW) 12PSIThe dyno's were all different. Is this a good/poor result, and expected for these changes? Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/ Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 21y 24d Gender: Male Location: Melbourne Posted 25/06/05 07:59 AM Share Posted 25/06/05 07:59 AM Mals BA XR6T said: I've just had a few things done, what are your thoughts...XR6T Auto1. Standard 186rwkW (5-6 PSI)2. Edit + Centre Muffler Removed + 2nd CAI 201rwkW (8PSI Map)3. X-Force 3" Exhaust + Injector Mod (high flow) + K&N Air Filter + 2nd CAI + Custom Tune 340rwhp (~250rwkW) 12PSIThe dyno's were all different. Is this a good/poor result, and expected for these changes?Your power levels with just edit and CAI sounded low. With your exhaust etc probably about right. Any mention of valve bounce because if so, change your valve springs and you should be good for ~280kw's at the wheels. Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266490 Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 21y 2m 13d Gender: Male Location: brisbane Posted 25/06/05 08:01 AM Share Posted 25/06/05 08:01 AM Mals BA XR6T said: I've just had a few things done, what are your thoughts...3. X-Force 3" Exhaust + Injector Mod (high flow) + K&N Air Filter + 2nd CAI + Custom Tune 340rwhp (~250rwkW) 12PSIThe dyno's were all different. Is this a good/poor result, and expected for these changes?Id want more then 250 rwkw with exhaust, injectors, filter, 2nd cai and custom tune... more like 270 or so I could be wrong though... I have similar mods and will get custom tuned early august.. I know its a month away but will let you know the results for comparisons sake.... Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266491 Share on other sites More sharing options...
Goldbullet Member 883 Member For: 20y 22d Location: Frankston Posted 25/06/05 08:03 AM Share Posted 25/06/05 08:03 AM I have round about the same mods and get 277rwkw Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266492 Share on other sites More sharing options...
Eugene Member 670 Member For: 20y 6m 30d Gender: Male Location: Newcastle NSW Posted 25/06/05 08:08 AM Share Posted 25/06/05 08:08 AM Mals BA XR6T said: I've just had a few things done, what are your thoughts...XR6T Auto1. Standard 186rwkW (5-6 PSI)2. Edit + Centre Muffler Removed + 2nd CAI 201rwkW (8PSI Map)3. X-Force 3" Exhaust + Injector Mod (high flow) + K&N Air Filter + 2nd CAI + Custom Tune 340rwhp (~250rwkW) 12PSIThe dyno's were all different. Is this a good/poor result, and expected for these changes?<{POST_SNAPBACK}>The first two sound a little low to me, but every dyno is different, so who knows, if you can go back to the first place you swere dynoed at and runagain, it will give you a better before and after than three different dynos.I was running 257 rwkw with injectors, STOCK EXHAUST< and xede. STOCK AUTO."hi flow cat" gained another 20 rwkw, and a APS system another 17 rwkw, the last three runs were on the same dyno, a few days apart, and were backed up on another dyno a few eeks later.So 250rwkw sounds a little low, but it may be the dyno, not your car, run it down the 1/4 and see what it does, it seems to stop all the BS. Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266494 Share on other sites More sharing options...
Mals BA XR6T Member 381 Member For: 22y 4m 12d Location: Sydney Posted 25/06/05 08:11 AM Author Share Posted 25/06/05 08:11 AM flukeyluke said: Any mention of valve bounce because if so, change your valve springs and you should be good for ~280kw's at the wheels.<{POST_SNAPBACK}>The valves are standard, and no problems yet.The injectors are also the original ones, but have been modified (I assume drilled out bigger somehow?) Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266495 Share on other sites More sharing options...
Goldbullet Member 883 Member For: 20y 22d Location: Frankston Posted 25/06/05 08:22 AM Share Posted 25/06/05 08:22 AM Mals BA XR6T said: flukeyluke said: Any mention of valve bounce because if so, change your valve springs and you should be good for ~280kw's at the wheels.<{POST_SNAPBACK}>The valves are standard, and no problems yet.The injectors are also the original ones, but have been modified (I assume drilled out bigger somehow?)<{POST_SNAPBACK}>U will need to get the valve springs done to hold your rwkw or the drop of is too short Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266499 Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 6m 4d Gender: Male Location: NSW Posted 25/06/05 08:23 AM Share Posted 25/06/05 08:23 AM Mals BA XR6T said: flukeyluke said: Any mention of valve bounce because if so, change your valve springs and you should be good for ~280kw's at the wheels.The valves are standard, and no problems yet.The injectors are also the original ones, but have been modified (I assume drilled out bigger somehow?)I think what he means Mal is if you change your valve springs to heavy duty, you should have no probs going to 280rwkw safely, which might be a bit sketchy with standard springs. Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266500 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 2m 14d Gender: Male Location: Sydney Posted 26/06/05 12:32 AM Share Posted 26/06/05 12:32 AM Did the dyno operator say anything? Like "if you go get the valve springs done, I can pull 280 no worries" or anything, that could be restricting the overall power output?Ive got 235, with 10psi, no custom tune, APS zaust, Typhoon FMIC and XR8 airbox. With injectors, id be expecting more than 250. Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266602 Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 6m 4d Gender: Male Location: NSW Posted 26/06/05 01:05 AM Share Posted 26/06/05 01:05 AM ms700 said: Ive got 235, with 10psi, no custom tune, APS zaust, Typhoon FMIC and XR8 airbox. With injectors, id be expecting more than 250.I agree.I've got 250rwkw with stock injectors, but I do have an auxillary fuel pump. With injectors, I'd want 300 if I had injectors in. Link to comment https://www.fordxr6turbo.com/forum/topic/18434-250rwkw-is-this-ok/#findComment-266607 Share on other sites More sharing options...
