Benny Member 1,869 Member For: 21y 7m 28d Gender: Male Location: Newcastle Posted 28/06/05 02:44 AM Share Posted 28/06/05 02:44 AM Just heard some info that the new auto gearbox will have a function called Winter Mode. This prevents the gearbox from changing up through the gears when the rear wheels have broken traction. From what I can understand the computer detects the speed of the front wheels and references them to the rears. This prevents the car from up shifting when wheels are rotating too fast for the vehicles overall speed. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 5m 23d Gender: Male Location: South Coast NSW Posted 28/06/05 03:23 AM Share Posted 28/06/05 03:23 AM Actually I think it works the other way around - will upshft and not shift back down ... Link to comment Share on other sites More sharing options...
Grass Donating Members 447 Member For: 21y 1m 17d Gender: Male Location: Sydney Posted 28/06/05 05:22 AM Share Posted 28/06/05 05:22 AM That's what the current range of European cars here with Auto's do.You turn "Winter" mode on and they take off in second, to avoid wheel spin.. Link to comment Share on other sites More sharing options...
rboksic Donating Members 514 Member For: 20y 11m 4d Posted 28/06/05 12:09 PM Share Posted 28/06/05 12:09 PM Grass said: Lawsy said: Grass said: I wait fHmm, some interesting points, but ... noYou have torque. The torque curve is flat. As long as your gear ratios keep you within the flat torque curve it don't matter if you have 1 or 5 gears.Just look at top fuelers......they run 2 or 3 gears at most..... if there was an advantage, as you are suggesting, then they would run 7,8,9 or 10 speed boxes.Sorry for the "slap stick" but Wannabe Mechanical engineer might be right...I have the bit of paper and the design time with gearboxes and diffs......Sorry.Top fuel only have a cluch pack and are direct drivePro Stock have gears 5 or moreRob Link to comment Share on other sites More sharing options...
