  • Member For: 21y 7m 2d
Hi All.
I have just picked up my new F6 and noticed that when changing gears, quickly, the engine seems to reduce power before coming on again!
Does anyone else have this issue?
A possible fix??
I removed the switch connected to the clutch (Tells the pcm that you are changing gears?? and used to deactivate cruise control) and now it seems to hammer right through. To the point that I am Extremely happy with the performance!! :blink:
Can this be a fix, or does the car eventually learn not to back off even with the switch connected??
I will reconnect it and see if it make a difference tomorrow!!
Has this topic already been covered?? :blink:
In fear of sounding like a wa*ker..I must say that I F&*^ing love driving this car!!
Cheers
:blush::blush:
https://www.fordxr6turbo.com/forum/topic/18125-changing-gears-in-a-manual-t/
  • Replies 40
Hi Bain,
I have traction control turned off...still does it.
Very painfull characteristic..
Does edit remove this???
Cheers
  • TEAM BA
  • Member For: 20y 4m 24d
I havnt got it, it *may* have been put in to try to save the clutch, I am guessing that ford could not handle having another clutch issue so wanted to try to limit the amount of abuse it gets...
  • Member For: 20y 2m 3d
  turbocorty said:
Hi Bain,
Cheers
<{POST_SNAPBACK}>
With TC off are you able to spin the rear wheels freely? or does it still correct it?
A few people have had problems where TC is still engaging even though its turned off.
  • Member For: 20y 1m 8d
<{POST_SNAPBACK}>
The Typhoon clutch is now much stronger than the XR6T standard one, and as a performance version I cant see them having less power across the rev range than the XR6T anywhere.
Sounds more like a fault that you should show the dealer to me.
I found that when new the 6 speed was a little slow to change, and got better from a bit of use. Maybe, you are just experiencing a slow change - and loss of boost? though - it shouldnt be affected by clutch switch I guess.
Edited by cobrav8
  • Wanabe mechanical engineer
  • Member For: 20y 7m 15d
The latest motor issue seems to agree that this is definately something electronic, or at least appears to be....
gees - in that case- how dumb of Ford! Why not pull a couple of plug leads off - that would save the clutch, gearbox and diff!
TurboCorty - maybe you will have to market your mod to Typhoon owners, what do you think its worth?
Edited by cobrav8
  • Member For: 21y 10m 4d
  turbocorty said:
Hi All.
A possible fix??
I removed the switch connected to the clutch (Tells the pcm that you are changing gears?? and used to deactivate cruise control) and now it seems to hammer right through. To the point that I am Extremely happy with the performance!! :tease:
Has this topic already been covered?? :wub:
Cheers
:wub:  :wub:
I still have this with mine and it's even more prominent now running higher boost.
The way I would describe this is:
- 2nd gear WOT
- clutch in, change to 3rd and WOT
- the gear engages, the revs start to climb BUT very little torque/push in the back.
- a second or so ticks by and BOOM. The torque returns and the revs start to climb faster.
Does this accurately describe what you are experiencing?
It appears to have nothing to do with traction control as it does the same thing whether TC is on or off (mine is almost always off). More likely, this is software related delay to protect the gearbox (torque tag?). I'm still running the generic 10PSI map rather than custom tune so this may be the reason.
The only other factor I can think of is that the car has to spool up boost again, but I haven't heard too many other complaining about this phenomenon...
  • Member For: 21y 8m 26d
I too have this delay/lag being mentioned. I find if I do quicker shifts including the footwork part it does not occur (the ones that sometimes result in chirps)
This leads me to believe its the driving style causing it. The timing of your clutch and accelerator replacement.
I'm confused now.. as I can remember it happening when changing quickly too.
Maybe its footwork consistency
Aidan
