God666 Complete Bastard Donating Members 1,123 Member For: 21y 5m 7d Gender: Male Location: Sydney Posted 13/06/05 01:06 AM Share Posted 13/06/05 01:06 AM An easy way to fix a sqeaky belt is to get a bar of handsoap and with the engine running, let it rub on the inside of the belt (the side with grooves).Be damn careful, it will take your fingers off if you *beep* up.Note for complete d1ckheads (if applicable), don't use laundry powder or liquid dishwashing detergent (thought I had better mention that).Suggest you get SWMBO to do the job, she won't miss a finger or two. Link to comment https://www.fordxr6turbo.com/forum/topic/18056-squeaking-belts/page/2/#findComment-262524 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 5m 27d Gender: Male Location: Adelaide Posted 13/06/05 01:12 AM Share Posted 13/06/05 01:12 AM I have what appears to be rubber dust obviously coming from the belt is this a problem with the belt and should I have it replaced? Link to comment https://www.fordxr6turbo.com/forum/topic/18056-squeaking-belts/page/2/#findComment-262526 Share on other sites More sharing options...
XR64T Are we there yet? Donating Members 703 Member For: 21y 7m 11d Gender: Male Location: Sydney, NSW Posted 13/06/05 06:42 AM Share Posted 13/06/05 06:42 AM I had this one to, sounded a little like the old loose fanbelt prob. Went away once the car warmed up. I annoyed the crap out of me.Dealer fixed it up at the 15K service, said they replaced one of the pulleys holding the serpentine belt as the bearing was rooted. Common problem apparently.Done another 35K since and no more issue. Link to comment https://www.fordxr6turbo.com/forum/topic/18056-squeaking-belts/page/2/#findComment-262605 Share on other sites More sharing options...
micksta Member 159 Member For: 20y 6m 17d Gender: Male Location: NSW Posted 13/06/05 10:16 AM Share Posted 13/06/05 10:16 AM Same here.Got the belt replaced under waranty 15km service, but it came back when its cold, belt grip spray seems to do the trick! Link to comment https://www.fordxr6turbo.com/forum/topic/18056-squeaking-belts/page/2/#findComment-262720 Share on other sites More sharing options...
