Centre Muffler Removal
geea
  • Skids?
  • Member For: 15y 6m 27d
Been ringing around some exhaust places... and some say it sounds better with the rear muffler removed anyone done it?
Edited by SPOOLAX
  • 5 weeks later...
  • 2 weeks later...
  • Member For: 15y 3m 13d
Got the center muffler moved yesterday. Done with two flanges and mandrel bends in 2.5" with two hot dogs. Ttl cost $254.00. At Windsor Exhaust, Richmond fellas there know what there doing would never regret sending someone there.I was told that the muffler is reduced internally to 2 2" inch bits so that would play a part in some restriction.
I think its a fair price sounds much deeper but not too loud, they have a gr8 exhaust note anybody thinking of doing this dont think twice you'll love it. When shifting down gears the car gives off a neat little burbble which is very easy to get used to :dontknow: .Admittedly it is a little noiser on start up but not in a bad way it sounds beefy. Hope this helps in some way thanks for all the info guys :beerchug: . The only mods I have is 10psi Generic tune from CAPA and the typhoon add-on for the air box with K&N filter panel and blow off valve is no longer the stock plum back it goes to atmospher but has a little filter on it preventing anything being sucked it when car is just over idle. All together with these simple mods the car sounds and goes gr8. (Looking 4ward to bigger injectors and fuel pump for the custom tune and a clutch that will frickin hold it all together) :3gears:
Edited by Brendan XR6-T
  • 5 weeks later...
  • Member For: 14y 10m 10d
Can anyone recommend an exhaust shop in the ACT to complete this mod or install a high flow cat into a stock exhaust?
Hey mate , just did mine yesterday (removed center muffler and got a 100 cell 3" cat installed)
Honestly....It stated up and I cringed it was hooniest sound ever...still cleaning vommit from my chest.
This morning rang the fellow to reinstall it.
He did it a few hours ago.
Get the Cat done and leave it there till you get the cash for a 2.5
' twin cat back or a 3.5" single cat back.
REALLY!!!!!!!!!!!!!!!!!!!!! :beerchug:
  • Member For: 17y 2m 21d
The stock exhaust system is barely audiable, you can hear more of the interiors creeking and cracking than the exhaust! When I had mine done I wasn't blown away, but there's a bit of a rumble taking off (under 2500rpm) which then turns into a roar. I couldn't go back to having the centre muffler there now as I've gotten used to it and quiet like it.
My next goal is to either put the centre muffler back and get rid of rear muffler, or just have a straight through system with no mufflers at all :spoton:
  • Member For: 18y 1m 20d
hey guys,
yesterday I decided to mod the centre muffler on my ba xr6 turbo, instead of removing it, I thought I would cut it open, run straight pipes thru it and weld it back up,
anyway, once I cut the top of the muffler I was "shocked" and disappointed, the muffler is already straight thru, with the only restriction being the perforated pipes are a little smaller in dia then the rest of the exhuast.
imo theres no way the centre muffler is much of a restriction, expecially when compared to a cat.
it did make it sound better, but with out improving flow (well bugger all), its pretty pointless, iam picking up a stock centre section tomorrow :(
anyone know if the rear muffler is straight through or baffled?
Edited by johnopaul
:buttrock:
hey guys,
I beleive Its also the same, :bopp: (in the earlier BA models)as I stated before get your CAT done etc...
If your in the ACT I can give you my old (good condition) centre :surrenderwave:
