Centre Muffler Removal
geea
  • Forged Member
  • Member For: 18y
If you had a hollow cat it most probably would be overboosting. However if the cat has collapsedit could be the reason your car doesn't want to rev.
Either way it will need replacing unless you want to get the car custom tuned.
  • Member For: 18y 4m 20d
But if the cat was stuffed, it would have been stuffed before I removed the central muffler, and it used to rev fine then.
I will be replacing the exhaust shortly anyway, but in the meantime, I want to still enjoy driving the T!
Will reset the ECU by disconnecting the battery and let it learn again. See what happens.
  • 2 weeks later...
  • ride the lightning
  • Member For: 18y 3m 27d
if you remove the centre muffler do you have to flash tune the car?my car has standard tune aftermarket cooler
  • Member For: 16y 10m 28d
nope
I have the muffler removed, stock tune and aftermarket cooler and no probs here
  • 3 weeks later...
  • Member For: 17y 10m 28d
howd u get it done mannn every place ive been they like can't remove centre muffler itll be too loud blah blah
Someone will do it.
What loaction you in. Someone here will be in the same area and tell you where they got theirs done.
Cheers
JR
  • 4 weeks later...
  • Member For: 16y 8m 10d
got quoted $187 to do this to my FG..Said sounded bit more exspensive that what other have paid to get this done and guy reckoned it was that because they use stainless to do it.
  • 3 weeks later...
  • Member For: 16y 4m 24d
Twin 3' stainless steel cat back exhaust, thoughts? Im not looking to go mega with the exhaust but I know someone in the industry n I can get that done for $1100 fitted..
Good choice?
  • Member For: 16y 6m 29d
I replaced everything from the cat back with single 3 inch stainless, resonator and junbl muffler and the difference is awesome gone from a big vacuum cleaner to a tough sounding car. there is a little drone but was told this would settle as the carbon builds up. wasn't chasing performance just a reasonable note but managed to grabb a few kw's but did managed to grabb a noticeable gain in the middle and response very slightly improved
