  • Member For: 19y 10m 23d
I HAVE RECENTLY DONE THE CAPA EDITED, AND NOW WANT TO GO TO 300KWRW. DO U THINKING BY DOING THE FOLLOWING WILL I ACHEIVED THAT. PLEASE GIVE ME ANY ADVICE AND HELP FROM THE PEOPLE WHO HAVE 300KWRW
• 6 x high performance fuel injectors
• Custom cast alloy rocker cover garnish
• Custom cast alloy intake plenum
• Custom intercooler hoses
• Cast alloy throttle body adaptor
• Cast alloy thermostat housing
• K&N air filter
• Fibreglass aid box
• Odyssey battery
• Battery box
• Battery cable
• Xede ECU
• Xede wiring harness
• Xede brass earth ring
• Inlet Manifold Studs
• Heat shrink
• Oil breather hose
• PCV hose
• Hose clamps
• Numerous cable ties
• Battery cable clips
• Injectors (XRT 350 and Stage 3)
• Large intercooler with lightweight end tanks
• Inlet Manifold, Intercooler, Intake Manifold and Battery tray nuts
• Brass fittings for plenum intake pipe, breather return hose and thermostat housing
• Several bolts, washers, T-pieces, loom extensions, and an earth clip
WILL I GET 300KWRWS BY DOING THE ABOVE.
THANKS
https://www.fordxr6turbo.com/forum/topic/17999-how-to-get-xr6-t-over-300kwrw/
  • Replies 24
  • Member For: 20y 7m 5d
rofl... you wont need 3/4 of that crap!!
all you'll need is:
Larger Cold air
performance filter (not necessary but deemed as "mandatory" by most)
Injectors
Edit (u already got but will need re-tuned)
Hi-flow exhaust + Cat
hi flo fuel pump
re-gapped plugs
intercooler
valve springs
get a custom tune by a good dyno shop once the mods have been performed and you should be well into the 310's
Edited by Trough Lolly
  • Seriously Flukey Member
  • Member For: 21y 23d
• K&N air filter
• Cold Air Intake
• Hose clamps
• Large intercooler
• Valve Springs
• Exhaust modification
You shouldnt need much more than that.
  • Toughest BA Turbo
  • Member For: 22y 3m 20d
Hey Muzza420,
I thought that list of components looked familiar.
That's the list of Nizpro Stage 2 components, taken word for word from their web site (ref http://www.nizpro.com.au/cobra_kits_main.html )
As per that website, price is $8750, tuned with Edit, for around 330rwkw.
I'd add valve spring and auto upgrade as well.
Why didn't you just say that's where you got the list from?
Brian
  • Member For: 19y 11m 10d
:gooff: This crowd's far too knowledgable to go about trying to rip off others ideas as your own!! :gooff::pooh::pooh:
  bcl said:
Hey Muzza420,
Brian
<{POST_SNAPBACK}>
mate, I never said that it was my idea, just read what I wrote. if it was my idea then I would not need your advice. this list was given to me by a nizpro dealer. please read carefully before you make a statement.
thanks
  xarh6turbo said:
Go down to HPF have a chat with ROB he will point you in the right direction and the cheapest way to get there
<{POST_SNAPBACK}>
mate can you tell me where I can find them, I am in wa.
thanks
