Turbo6man Lifetime Members 4,084 Member For: 22y 6m 25d Gender: Male Location: South Coast NSW Posted 08/06/05 08:07 AM Share Posted 08/06/05 08:07 AM sixfan said: Anyways, Walbro fuel pump, injectors and a valve springs next I guess...Custom edit and well see what it'll do then.<{POST_SNAPBACK}>So you're saying the tune you have is all above board for what it is supposed to be?Seems odd to me that an edit could be supplied that would see the car limited even more at the top end than the standard vehicle??? Is it the same through the gears? I can understand that the standard fuel pump and injectors would not be able to sustain full boost of say 8psi all the way to redline but surely it could be controlled so that the boost didn't drop any further than the standard 4 psi map at the high end of the rev range? From what you've reported they must be allowing more boost low and mid range but severly cutting it in the high range. Just seems all a bit incongruous to me. Link to comment https://www.fordxr6turbo.com/forum/topic/17969-edited-ts-top-speed/page/5/#findComment-261016 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 16d Gender: Male Location: Zombie Birdhouse Posted 08/06/05 01:04 PM Share Posted 08/06/05 01:04 PM Turbo6man said: sixfan said: Anyways, Walbro fuel pump, injectors and a valve springs next I guess...Custom edit and well see what it'll do then.<{POST_SNAPBACK}>From what you've reported they must be allowing more boost low and mid range but severly cutting it in the high range. Just seems all a bit incongruous to me.<{POST_SNAPBACK}>Sounds like a dealer edit This is exactly what Ford did to the Phoons pre "the troubles". That little extra protection at the expense of performance.Just got to have these beasties custom tuned.Sorry but I just cant plug and play. Link to comment https://www.fordxr6turbo.com/forum/topic/17969-edited-ts-top-speed/page/5/#findComment-261228 Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 21y 11m 14d Gender: Male Location: NOONAMAH, go figure..... Posted 09/06/05 05:14 AM Author Share Posted 09/06/05 05:14 AM Buf-Phoon said: Turbo6man said: sixfan said: Anyways, Walbro fuel pump, injectors and a valve springs next I guess...Custom edit and well see what it'll do then.From what you've reported they must be allowing more boost low and mid range but severly cutting it in the high range. Just seems all a bit incongruous to me.Sounds like a dealer edit This is exactly what Ford did to the Phoons pre "the troubles". That little extra protection at the expense of performance.Just got to have these beasties custom tuned.Sorry but I just cant plug and play. Yeah, I'm not sure... I phoned CAPA and they told me to call the bloke I got it from. I may still have a leaky IC hose, I doubt it, but I need to check everything else before I go assuming the edit deaded the top-end....The tailpipe certainly looks white and lean-as, therefore I'll be running the 8psi map until the custom tune. Logic behind the mods is more that I was going to do it anyway, so I may as well only pay for the edit tune once. Link to comment https://www.fordxr6turbo.com/forum/topic/17969-edited-ts-top-speed/page/5/#findComment-261369 Share on other sites More sharing options...
theeone Member 349 Member For: 21y 11m 17d Location: Hoddles Creek (VIC) Posted 09/07/05 11:19 AM Share Posted 09/07/05 11:19 AM Tailpipe won't run grey or white as far as lean goes, cause there's no lead in your guzzoline Link to comment https://www.fordxr6turbo.com/forum/topic/17969-edited-ts-top-speed/page/5/#findComment-271130 Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 21y 11m 14d Gender: Male Location: NOONAMAH, go figure..... Posted 10/07/05 11:40 AM Author Share Posted 10/07/05 11:40 AM theeone said: Tailpipe won't run grey or white as far as lean goes, cause there's no lead in your guzzoline Hmm. Didn't know that! Guess I'm showing my age Still...It looks a lot lighter than it used to.Update, I can't even get over 160 with the standard map loaded now....I've replaced the spring clips on all the IC hoses I can't find a leak and the T seems to be running ok, just no power. I gave up and got the daimler back on the road. rebuilding injectors @ $40 a pop aint a cheap excercise when you've got 12 of them... Link to comment https://www.fordxr6turbo.com/forum/topic/17969-edited-ts-top-speed/page/5/#findComment-271446 Share on other sites More sharing options...
