Turbo Problem
Guest crushx69
Guest crushx69
  • Guests
Has anybody heard of this happening I have a dec03 xr6t 110,000klm I noticed a slight noise from exhast manafold, I took it to the exhast shop only to find that 2 studs had broken of in the turbo and one was missing and all the other bolts where loose. :spoton:
  • still kicking around
  • Member For: 21y 9m 22d
I have heard of it happening to cars with less kays on it
if you dont mind me asking, how the hell did u clock up so many kays in 2yrs
  • Dark Knight Mafia Member No. - 666
  • Member For: 21y 10m 19d
please explaing this noise, I currently have a fluttering noise of escaping exhaust coming from around the turbo area, it turn into a squeel when I accelerate. The noise goes away once the exhaust pipe warms up and expands. Does this sound similar to what your experienceing?
Dazza.
  • Member For: 21y 3m 4d
I had this problem. Turned out to be loose bolts on the turbo manifold. Its worse when cold, then when it heats up it expands a bit closing where the air is escaping from. Take the heat shields off around the turbo and tighten all bolts. Fixed my problem you guys are talking about. :blink:
Guest crushx69
  • Guests
What can I say it is a nice car to drive plus with work a get around quiet abit. So have given it quiet a workout and must say only for the turbo problem and a water pump seal that is all that has gone wrong with it. I am quiet happy with my car soon will get series 2.
Guest PSIXR6
  • Guests
Yes this is a common thing to happen on turbo cars, the flange bolts to come loose after time, and do need to be checked. I do believe it read it in the cars sevice books that a certain checks they must inspect and tighten the exhaust flange bolts.
  • Team HgAg
  • Member For: 20y 2m 8d
I had that fluttering noise on the way home today from work.. It usualy only happens once in a blue moon.. but for a bit of experience I decided to have a look at the turbo manifold just to see if there were any loose bolts..
Gettin the heat shield off 2 min ( easy part )
Checked all the bolts, they were all fine.. When would be the best time to check these bolts??? First thing in the morning or after the T has been run
Trying to get that bolt back on in the heat shield... :spoton: an hr..... Could not get it lined up plus it was so small.. must of only had about 1 1/2cm of thread on it
Ahh well took it for a spin afterwards and gave it a right old flogging and no fluttering this time... And all my hose's stayed on :spoton:
cikas
  • Phantom lives
  • Member For: 20y 8m 23d
Check the bolts when the engine is cold - ie. first thing in the morning.
Ross
<{POST_SNAPBACK}>
I agree Ross we have noticed it here at work all the time. I have replaced mine before broken and missing..
jeff
