  • Member For: 22y 4m 5d
Got this annoying squeak in rear near hand brake cable. Not sures if only utes are affected.
Local Ford dealer said it was a drum(?) where hand brake cable it, fills with brake dust (etc) then starts to squeak, to fix brake assembly needs to be pulled apart to clean and replace but was told it will develop again over time. WTF?
They also said a fix was comming but didn't know when.
The squeak is now getting farking loud, stops when braking. I can wait another 9k till next service im going to have to get it fixed.
Anyone else had annoying problem or know about a fix or one comming?
Cheers,
Ford Grunt (Ben)
  • Member For: 20y 10m 12d
Man I have the same problem!everytime I go say 40km or under I get sh sh sh with squeeks now. wasn't bad enough with sh sh sh now this!
  • HgAg soldier
  • Member For: 21y 10m 28d
hehe I was walking down the main street this afternoon after getting some lunch and I heard the shh shh shh sounds and I thought to myself that has got to be a BA.. sure enough I looked up and it was a BA Fairmont...
mine does it too :(
  eMPee said:
check out this thread http://www.fordxr6turbo.com/forum/index.ph...topic=17196&hl=
ive gotta find time to do it, its buggin the sh*te outta me
<{POST_SNAPBACK}>
Thanks for that I checked it out.
Dont know about you guys but the squeeking is so loud in mine that you can hear it with the windows up and the stereo going at a decent level.
Its fustrastrating being a fairly tough looking ute, squeeking and sounding like a piece of sh*t from the street.
  • 2 weeks later...
  • Member For: 20y 7m 17d
I get the same squeak over small pot holes and bumbs in the road.
try squirting a bit of WD40 into the rear brake calipers, its stops the squeak for a couple of months, its works for me.
Your right it gives you the :pooh:
micksta :spoton:
