N SPOOL Member 7 Member For: 20y 2m 3d Location: WOLLONGONG Posted 02/05/05 08:01 AM Share Posted 02/05/05 08:01 AM hay guys and girls,my brother was standing by my car when I TURNED IT OFF the other day and he heard a noise from the turbo,like a bearring noise.Anyway I took it in to ford and the turbo is on its way out. They have a new one on the way so that's good and told me to take it easy also I still have a bad miss on idle they put a new throtle body in but it didnt help not to happy..SO CHECK YOUR TURBO Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 1m 19d Gender: Male Location: In my house Posted 02/05/05 08:29 AM Share Posted 02/05/05 08:29 AM As my sig says,I think my turbo is fine LOL Link to comment Share on other sites More sharing options...
CHIPS Great rack Donating Members 1,351 Member For: 21y 11m Gender: Male Location: Geelong Vic. Posted 02/05/05 08:33 AM Share Posted 02/05/05 08:33 AM hay guys and girls,my brother was standing by my car when I TURNED IT OFF the other day and he heard a noise from the turbo,like a bearring noise.Anyway I took it in to ford and the turbo is on its way out. They have a new one on the way so that's good and told me to take it easy also I still have a bad miss on idle they put a new throtle body in but it didnt help not to happy..SO CHECK YOUR TURBO ...Cripes, mine makes a "whirring" sort of "worn-out-bearing" kind of noise after turning off also. I was told it is normal .........better get it looked at! 1 Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 6m 2d Gender: Male Location: Perth, WA Posted 02/05/05 09:05 AM Share Posted 02/05/05 09:05 AM That is quite odd for these turbos, I guess there could be faulty ones from the factory but they are designed to pretty close tolerances. Things that cause bearing failure are dirty oil and too much boost... I can't see it being the latter! Bizarre. Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 8m 30d Location: Mildura Posted 02/05/05 09:12 AM Share Posted 02/05/05 09:12 AM hay guys and girls,my brother was standing by my car when I TURNED IT OFF the other day and he heard a noise from the turbo,like a bearring noise.Anyway I took it in to ford and the turbo is on its way out. They have a new one on the way so that's good and told me to take it easy also I still have a bad miss on idle they put a new throtle body in but it didnt help not to happy..SO CHECK YOUR TURBO<{POST_SNAPBACK}>Chips,The turbo still keeps spinning for a short time after you turn the engine of and makes a bearing sound. That sounds normal to me. The miss at idle is more of a concern to me, as it would have nothing to do with the turbo.macka Link to comment Share on other sites More sharing options...
xr6t ute Member 442 Member For: 20y 10m 9d Gender: Male Location: Gold Coast Posted 02/05/05 09:13 AM Share Posted 02/05/05 09:13 AM Mines always made a slight noise when turned off, just the impeller winding down I was led to believe. Always change my oil at 5000km as well. Must really make a fair bit of noise if something goes wrong Shane Link to comment Share on other sites More sharing options...
CHIPS Great rack Donating Members 1,351 Member For: 21y 11m Gender: Male Location: Geelong Vic. Posted 02/05/05 09:23 AM Share Posted 02/05/05 09:23 AM Mines always loudest when I park in the garage because the sound reflects off the walls and floor, and there are no other noises.....it sounds ............There are no noises at all from it when the engine is running/has oil press to it. Link to comment Share on other sites More sharing options...
C.S.I Member 651 Member For: 20y 2m 10d Gender: Male Location: Gold Coast Posted 02/05/05 10:17 AM Share Posted 02/05/05 10:17 AM Mines always loudest when I park in the garage because the sound reflects off the walls and floor, and there are no other noises.....it sounds ............There are no noises at all from it when the engine is running/has oil press to it.<{POST_SNAPBACK}>Chips, mine is parked in the garage every night, concret floor, brick etc. (Where else would you park your T )I have never heard a 'spool down' noise from it ever. Dont believe that the noise you are hearing can be good All I can hear is the water boiling away as the turbo cools down.It would pay to get her checked out... Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 10m 1d Gender: Male Location: Brisbane Posted 02/05/05 10:33 AM Share Posted 02/05/05 10:33 AM Mines always made a slight noise when turned off, just the impeller winding down I was led to believe. Always change my oil at 5000km as well. Must really make a fair bit of noise if something goes wrong Shane<{POST_SNAPBACK}>Hey, what have you done with tango? Mine's always made a slight noise as well, but sounds like a healthy noise rather than a metal-on-metal spine-tingling kind of grinding noise.Trent. Link to comment Share on other sites More sharing options...
xr6t ute Member 442 Member For: 20y 10m 9d Gender: Male Location: Gold Coast Posted 02/05/05 10:43 AM Share Posted 02/05/05 10:43 AM Mines always made a slight noise when turned off, just the impeller winding down I was led to believe. Always change my oil at 5000km as well. Must really make a fair bit of noise if something goes wrong Shane<{POST_SNAPBACK}>Hey, what have you done with tango? Mine's always made a slight noise as well, but sounds like a healthy noise rather than a metal-on-metal spine-tingling kind of grinding noise.Trent.<{POST_SNAPBACK}>Just thought it was time for a name change trent, something a bit more car related.Shane Link to comment Share on other sites More sharing options...
