Exhaust Heat Shield Rattle and Removal (Merged Topic)
SweetXR
  • Dark Knight Mafia Member No. - 666
  • Member For: 21y 8m 22d
How come your dealer hasn't replaced it with a new one then?
Your first post made it read like you just got sick of it and pulled it off yourself.
  • Member For: 21y 1m 10d
7 times I went to the dealer to get it fixed but with no luck, I was sick of them pulling it off then putting it back on then hitting it tightening it strapping it replacing it so it was taken off, I have had no issue and have check it last week an no heat scoring on the body at all it's all good. blink.gif
Edited by Dagabond
  • 8 months later...
  • Here since the start...
  • Member For: 21y 6m 21d
Hi guys,
The heat shielding on my exhaust rattles like crazy, especially when cold and the heat from the engine starts expanding things. My dealer has tried fixing it 4 or 5 times now and it works for a little while but always comes loose again. Ford won't replace the shielding to the later design they put on because you can't buy it separately, it only comes on the cat section of the exhaust.
Have any of you guys with standard or modified standard exhaust completely removed the heat shields?
Has it caused any problems? No melting or burning of the underbody?
Cheers,
Adam. :laughing:
Mine has about 4 brackets on it and for a while it works but always starts to rattle again!
  • Im the one and only
  • Member For: 19y 10m 9d
Adam.Go and buy 2 or 3 big hose clamps big enough to fit around the sheild and tighten them up.
This worked for me when I had stock exhaust on.
  • Member For: 19y 8m 24d
Mine rattled like crazy - drove me NUTS! I got it up on the hoist and just removed the whole thing. I haven't had any problems with heat, and considering I live in Darwin with 30+ degree ambient temps every day I'm sure it shouldn't be a problem somewhere cooler.
All you need to take it off is a couple of 10mm spanners / sockets, side cutters (pliers or wire cutters), a hoist, maybe a pry bar or something similar and a bit of patience!
I had to remove the exhaust rubbers to get enough room for the upper part of the shield to come off, but otherwise it was pretty easy!
The only time it may get a bit too hot is if you get stuck in traffic - something that luckily hardly exists up here!!!
  • Member For: 20y 9m 15d
I have seen one car on a hoist that had that metal packing tape stuuff around it on three different spots..... I spoke to the owner... he said he had heat shield rattle but didnt know they fixed it with packing material.
  • Member For: 19y 11m 28d
well I had my car back at the dealer the other day and while it was there they commented on it rattling so it is going back in a few weeks to have the whole heat shielding replaced. hopefully this will fix it as it is damn annoying
