  • Site protagonist
  • Member For: 22y 1m 10d
I noticed when I was changing my wheels today that the inside drivers rear was wearing more than the rest of the wheel. It looks like some of this may have been caused by wheelspin. Is there a way of rectifying this or is only a problem when the wheels are spinning?
Geea. :spoton:
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/
  • Great rack
  • Member For: 22y 2m 27d
Geea. :spoton:
Are you fair dinkum Craig? :spoton:
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-247905
  • Xtreme Xalted Member
  • Member For: 22y 1m 16d
Geea. :spoton:
Dear Hoon boy,
I'm sure it will all work itself out.
Just get your wife to cook you a nice dinner.
Put your front wheels on the back and vise-versa.
If this doesn't work, have a nice cup of tea and a lie down.
Yours,
Dorathy Dix.
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-247914
  • Site protagonist
:spoton:
Ok guys I'll try and explain it abit better.
Is it possible that the rear suspension of the car needs to be adjusted because it has been lowered. Is the suspension able to be adjusted and if so would I be better off asking HPF, a tyre place or a suspension place.
Or does the inside of tyres wear more than the rest because of wheelspin. I would have thought that the tyre would have even wear accross the whole surface regardless of how it was driven. :spoton:
Geea. :spoton:
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-247917
  • EMS makes MAGIC MUMBO !
  • Member For: 21y 6m 10d
Geea,
In theory a tyre should wear evenly, but you must have too much negative camber on the rear (Good for cornering hard, not for tyre wear)
This could be just an out of adjustment (I believe there is sone adjustment in the rear), Could have been adjusted to give the wheel clearance at the top to the guard because of the width (Not likely I would imagine), this will probably happen as the car squats under acceleration anyhow, so even if adjusted properly, you may not get rid of it !
I'd swing past a good tyre place, as they will be able to have a look for you !
Pretzel
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-247923
  • In Your Face
  • Member For: 22y 3m 13d
  geea said:
:w00t2:
Or does the inside of tyres wear more than the rest because of wheelspin. I would have thought that the tyre would have even wear accross the whole surface regardless of how it was driven. :w00t2:
Geea. :w00t2:
<{POST_SNAPBACK}>
Need to ajust your Toe In Craig by the sounds of it.
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-247928
  • Member For: 22y 8m 11d
Basically what Pretzel said Craig ... with the lowering of your car together with the rear squatting under hard accelleration, may mean there is now too much negative camber. A good suspension place can sort it for you pretty quickly as I believe the rear is adjustable. If not I'm sure there will be a big enough hammer in the workshop that will do the job eh
:w00t2::w00t2:
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-247939
  • Member For: 21y 9m 29d
Well I've had a few beers but thnking about it, if you watch drag cars the front left lifts up often off the tarmac, placing weight on right rear tyre. You would think this would let the left rear spin and wear more but with a LSD independent maybe not but what it may do is lift the inside of the right rear slightly thus waering out the outside of the right rear, whilst the left rear suspension without the weight balances itslef considering the are independent.
Or should I just go for another beeer?
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-248009
<{POST_SNAPBACK}>
Good theory....... Except it's the inside right rear that's wearing........
Time for another beer or two ! :spoton:
https://www.fordxr6turbo.com/forum/topic/17292-tyre-wear/#findComment-248024
