F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 20d Gender: Male Location: Strapped in and holding on Posted 02/05/05 11:07 AM Share Posted 02/05/05 11:07 AM F6_Tornado said: AdamXR6T said: Well look in here then. There maybe some useful info it there somewhere or PM Eugene for the part number. This thread is where I got the PDF file from. Eugene's Injectors for Sale Thread<{POST_SNAPBACK}>Done that many times but still cant get anything concrete on his injectors and it looks like most others are tuning to the injector they use.Looks like its all a bit hit and miss <{POST_SNAPBACK}>You gotta get that custard hay hauler b4 u can mod it Greggles... I get mine in exactly 11 DAYS.............................. hooo yawwwww... Does urs have wheels yet?? Link to comment https://www.fordxr6turbo.com/forum/topic/17285-bigger-injectors-a-problem/page/3/#findComment-248841 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 27d Location: In The Ute Posted 02/05/05 11:17 AM Author Share Posted 02/05/05 11:17 AM XRT UTE said: You gotta get that custard hay hauler b4 u can mod it Greggles... I get mine in exactly 11 DAYS.............................. hooo yawwwww... Does urs have wheels yet??<{POST_SNAPBACK}>^@#$*^#$*)(^(_^&$%*^#*)(^*^%#&$&(%*() Link to comment https://www.fordxr6turbo.com/forum/topic/17285-bigger-injectors-a-problem/page/3/#findComment-248850 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 9d Gender: Male Location: Victoria Posted 03/05/05 11:33 AM Share Posted 03/05/05 11:33 AM Surely someone who has these injectors could look at the part number and post it up here for you... Link to comment https://www.fordxr6turbo.com/forum/topic/17285-bigger-injectors-a-problem/page/3/#findComment-249196 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 27d Location: In The Ute Posted 03/05/05 12:04 PM Author Share Posted 03/05/05 12:04 PM AdamXR6T said: Surely someone who has these injectors could look at the part number and post it up here for you...<{POST_SNAPBACK}>I think its a case of most people don’t know what they are using and if they are good or bad There are a lot of unanswered questions which only tells me that most don’t know and some that do don’t want to let others know they might well be using the wrong injectors.I’ve yet to see an injector and spec sheet that meets the right ohms and spray design with around 400+ cc’s Link to comment https://www.fordxr6turbo.com/forum/topic/17285-bigger-injectors-a-problem/page/3/#findComment-249216 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 20d Gender: Male Location: Strapped in and holding on Posted 03/05/05 01:22 PM Share Posted 03/05/05 01:22 PM F6_Tornado said: I’ve yet to see an injector and spec sheet that meets the right ohms and spray design with around 400+ cc’s <{POST_SNAPBACK}>Gotta remember, no specs are available for inj's at 4 bar. everything is rated at 2.7 or 3.. Do some calcs, it mat be the 968's are 400 @ 4Bar?? Link to comment https://www.fordxr6turbo.com/forum/topic/17285-bigger-injectors-a-problem/page/3/#findComment-249235 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 27d Location: In The Ute Posted 03/05/05 09:55 PM Author Share Posted 03/05/05 09:55 PM XRT UTE said: F6_Tornado said: I’ve yet to see an injector and spec sheet that meets the right ohms and spray design with around 400+ cc’s <{POST_SNAPBACK}>Gotta remember, no specs are available for inj's at 4 bar. everything is rated at 2.7 or 3.. Do some calcs, it mat be the 968's are 400 @ 4Bar??<{POST_SNAPBACK}>Show me the spec sheet on 2.7 bar and I think I'm smart enough to do the calc if you have the sheet Besides we have the spec sheet on the 968's and the 123 STD its the others that are available around the traps that have no spec sheets to compare.That is my point......Apart from the ohms the 968 looks the goods but I cant say that about the rest without specs and as such I'm damn sure I wouldnt be using them Link to comment https://www.fordxr6turbo.com/forum/topic/17285-bigger-injectors-a-problem/page/3/#findComment-249254 Share on other sites More sharing options...
