  • Replies 21
  • Member For: 20y 11m 4d
  rednut99 said:
What if you have modified injectors and you flash the stock map back on? Won't the car run like sh*t and over fuel?
Is this a case for a Valet tune?
<{POST_SNAPBACK}>
I'm lead to believe that, there is a third tune that comes with the Edit designed to run the engine for customers using larger injectors.
If you have larger injectors their is no way that you could allow Ford to reflash the PCM as it would overwrite this tune. The car would then run like :spoton: and they would be all over it trying to get it to run properly.
Best thing to do is be up front and tell them what you have done. Come to an agreement that if there is a failure and they can prove that your mods have caused the failure you'll pay.
I had the EMS under the dash the Shaker and all it new plumbing larger injectors and IC for all the mechanics and service manager to see. They still replaced the transmittions under warranty. :spoton:
macka
