Silverbullet Member 100 Member For: 21y 8m 10d Location: Brisbane Posted 28/04/05 11:30 AM Share Posted 28/04/05 11:30 AM XXXR6T said: The edit box stores your tunes in it. Best thing to do is store the stock tune and when you have to get it serviced download the stock maps and when you get it back download the tuned maps <{POST_SNAPBACK}>Is there any truth that Ford servicing departments purposely install so called "ECU updates"..............which in fact plays havic with the ability of the "Edit" to perform once the standard ECU has been reflashed?, or is this just a rumour. Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247705 Share on other sites More sharing options...
C.S.I Member 651 Member For: 20y 4m 15d Gender: Male Location: Gold Coast Posted 28/04/05 12:29 PM Share Posted 28/04/05 12:29 PM Silverbullet said: Is there any truth that Ford servicing departments purposely install so called "ECU updates"..............which in fact plays havic with the ability of the "Edit" to perform once the standard ECU has been reflashed?, or is this just a rumour.<{POST_SNAPBACK}>that's plain wrong !!The Ford Factory flash can and does play havoc with the piggybacks.Has no affect of the 'Edit', as you just flash back your own tune when you get your car home Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247724 Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 10m 4d Posted 29/04/05 02:59 AM Share Posted 29/04/05 02:59 AM I have a good example to answer your question.Mine was in at Ford to have some work done very recently. When I picked the car up, I noticed that they had broken off one of the small hinges which keeps holds the fuse box cover on.The work I had done, had nothing to do with the ECM, so why would they have needed to open this? More than likely a flash upgrade of the software. NOTE, nothing was mentioned to me about this when I picked up the car.I didn't particularly care that the upgrade had been done, since 5 minutes later the software was replaced anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247862 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 2m 17d Gender: Male Location: Sydney Posted 29/04/05 03:20 AM Share Posted 29/04/05 03:20 AM SIXRT,Do not forget you have just overwritten the latest update with the Edit.Next time you go in for service and flash it back to stock, your versions will be conflicting.Ford will say its version x.xx, yet version y.yy will be on the car. This will make Ford sevice a bit sus because it has gone back a version. Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247872 Share on other sites More sharing options...
God666 Complete Bastard Donating Members 1,123 Member For: 21y 4m 27d Gender: Male Location: Sydney Posted 29/04/05 03:59 AM Share Posted 29/04/05 03:59 AM vixen said: And you guys are positive that the Service people at ford can't pick it up?Aren't we allowed to go for services to Ultra Tune etc, which also doesn't void warranty, I'm sure that those guys would never even pick up if a tune existed.You guys all seemed to have jumped to the conclusion that Ford dealers actually open your bonnet when they service your car. Ever heard of the 40ft spanner? As long as a spanner is waved at your car within 40ft, the service is deemed to have been done. Voila....A bit harsh but given the experience of some members on this forum, possibly appropriate. Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247882 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 6m 21d Gender: Male Location: South Coast NSW Posted 29/04/05 04:02 AM Share Posted 29/04/05 04:02 AM Yes Zap, that is the only flaw in the edit. I personally think you are better off being honest with the dealer and saying "hey, I don't want you to touch my edit and just leave the old version in there." I would reset it though to the standard version before lettting the service guys get their mits on it and take it for a drive ... Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247884 Share on other sites More sharing options...
Gary Crawley Member 313 Member For: 20y 3m 1d Location: Southern Highlands Posted 29/04/05 08:30 AM Share Posted 29/04/05 08:30 AM Please correct me if I'm wrong, but can't you suck the current Ford edit from the car and then download you own edit.Won't this mean that if you return your car back to standard for service etc, it will be at the last Flash version Ford applied.So there should be no version missmatch.RegardsCreepy Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247945 Share on other sites More sharing options...
C.S.I Member 651 Member For: 20y 4m 15d Gender: Male Location: Gold Coast Posted 29/04/05 08:36 AM Share Posted 29/04/05 08:36 AM OK Creepy, Heres the correction The CAPA Box ONLY uploads into itself your original Ford Factory tune ONCE.After this, it does not ever reload it. Therefore if Ford does re-flash your car, it will not match that of your Flash Tuners Stock F slot.The only workaround for this would be to have the CAPA Box reset (use a life, max of 5), then it would re-upload the factory flash back in at next use. Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247949 Share on other sites More sharing options...
Gary Crawley Member 313 Member For: 20y 3m 1d Location: Southern Highlands Posted 29/04/05 08:40 AM Share Posted 29/04/05 08:40 AM C.S.I said: OK Creepy, Heres the correction The CAPA Box ONLY uploads into itself your original Ford Factory tune ONCE.After this, it does not ever reload it. Therefore if Ford does re-flash your car, it will not match that of your Flash Tuners Stock F slot.The only workaround for this would be to have the CAPA Box reset (use a life, max of 5), then it would re-upload the factory flash back in at next use.<{POST_SNAPBACK}>Thank youCreepy Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247950 Share on other sites More sharing options...
C.S.I Member 651 Member For: 20y 4m 15d Gender: Male Location: Gold Coast Posted 29/04/05 08:47 AM Share Posted 29/04/05 08:47 AM Turbo6man said: Yes Zap, that is the only flaw in the edit. I personally think you are better off being honest with the dealer and saying "hey, I don't want you to touch my edit and just leave the old version in there." I would reset it though to the standard version before lettting the service guys get their mits on it and take it for a drive ...<{POST_SNAPBACK}>Or put in the Valet tune Link to comment https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/page/2/#findComment-247953 Share on other sites More sharing options...
