  • Member For: 20y 10d
Apologies for my lack of knowledge in this field, but I need a little learning with regards to installing an edit and the ongoing maintenance of a vehicle with one fitted.
Scenario:
I get an edit installed and get it dyno tuned so its running tops. Then comes along the 12 month service which I have to get done at the dealership so they will tune it to the factory specs.
So where does that leave the tune of the edit? Do I have to get it tuned AGAIN with the edit 'specs'? Or will I simple plug the edit back in and its back to its A1 dyno tune spec again and I can forget about it for another 6 months?
Just need clarification on this somewhat basic arrangement.
Thanks!
https://www.fordxr6turbo.com/forum/topic/17247-edit-servicing/
  • Replies 21
  • Colossal Member
  • Member For: 20y 8m 7d
The edit box stores your tunes in it. Best thing to do is store the stock tune and when you have to get it serviced download the stock maps and when you get it back download the tuned maps :)
  • Powered by Ford's 3.7 V6 = Zoom Zoom Zoom!
  • Member For: 20y 6m 1d
  Terebro said:
OK thanks, but can this 'downloading' be done in my own garage?
Whats involved?
<{POST_SNAPBACK}>
Yes, you can even pull over to the side of the road on your way home from the service. It's a simple task, don't even have to get out of the car, and takes about 3-4 mins of your time. You can change tunes as often as you like.
Cheers Clarke :spoton:
  • Member For: 20y 4m 18d
And you guys are positive that the Service people at ford can't pick it up?
Aren't we allowed to go for services to Ultra Tune etc, which also doesn't void warranty, I'm sure that those guys would never even pick up if a tune existed.
  • Yes I am too tall for my hair
  • Member For: 20y 7m
1 Would you like someone from ultra tune to be driving your car with 250 - 300 ++ rwkw
2 ford will do any thing to void warranty mine did this morning centre muffler removed and k/n filter = no more warranty
3 Get the edit they will never no
  • loitering with intent
  • Member For: 21y 8m 12d
<{POST_SNAPBACK}>
Think I would be speaking to the dealer Principal.........that is total BS.
and what will the removal of the centre muffler and k/n filter do to cause component failure, absolutely nothing :censored:
  • Colossal Member
First they would have to prove that the modifications were the sole cause of the failure before they can void your warranty. I talked to the head techo at my dealer and he said there's no problem with mods and warranty as long as they can prove your mods werent the cause. He said they look at it on a case by case basis anyway.
  • In Your Face
  • Member For: 22y 1m 22d
  WhiteTee said:
<{POST_SNAPBACK}>
and what will the removal of the centre muffler and k/n filter do to cause component failure, absolutely nothing :pooh:
<{POST_SNAPBACK}>
WTF.........my dealer know every mod l have and they still warrant mine :pooh:
