Paulie2256 Donating Members 7,441 Member For: 16y 3m 4d Gender: Male Location: SE Melbourne Posted 25/03/12 06:25 AM Share Posted 25/03/12 06:25 AM (edited) Unrelated note: Don't you hate it when you tighten the dump pipe with a torque wrench set to 20 foot pound the the fker snaps anyway?PS: how do I fix it? Drill something into it and remove the stud then screw new stud in? Where do I get the new stud from stud?Ps shifter thread?So ended up taking the dump off and getting the broken stud out by hand pretty easily. Thought I might as well replace all of the studs and nuts at the same time. Ended up snapping 2 others. This time they are inside the turbo housing.1st try - Left hand drill bit. The trick is drilling a hole in the dead centre of the stud. Since I can't see the stud at all I completely miss and drill a whole to one side both times.2nd try - Screw extractor. Fail already because the 1st step failed.3rd try - Drill out the rest of the stud as much as possible. This is very time consuming because I didn't want to hurt the original thread. Also, there is hardly any room for the drill.Anyway, almost drilled both of the studs out completely. Now what?Tap the original thread while grinding away the rest of the old stud. This requires patience like you wouldn't believe. Oil the tap, forward backward, forward, backward, oil, repeat.So what has this got to do with anything? Henz, the tap and die kit came with a thread pitch gauge, the shifter thread size is 1.5Ps: I'm starting to think I put the studs in backwards hahahahha Edited 25/03/12 06:32 AM by Paulie2256 Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 4d Gender: Male Posted 25/03/12 06:39 AM Share Posted 25/03/12 06:39 AM (edited) Was up at the farm today chopping wood with the old man Alright we cheated used the log splitter.while walking around stumbled across the massive mushroom, was thinking about eating, but thought I might not be here tommorow and you will miss me. Check out the size of it.whoever wants it let me know and will bring it back for you.Oh click pic's for bigger version. Edited 25/03/12 06:41 AM by PAZZOnegger Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 11m 6d Gender: Male Location: Vic Posted 25/03/12 06:41 AM Share Posted 25/03/12 06:41 AM Interesting. 1.5x? Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 4d Gender: Male Location: SE Melbourne Posted 25/03/12 06:52 AM Share Posted 25/03/12 06:52 AM 1.5mm, it's a metric thread. Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 3m 12d Gender: Male Location: Dé·jà vu Posted 25/03/12 07:52 AM Share Posted 25/03/12 07:52 AM 1.5mm pitch whats the diameter... Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 11m 6d Gender: Male Location: Vic Posted 25/03/12 08:10 AM Share Posted 25/03/12 08:10 AM What he said. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 4d Gender: Male Posted 25/03/12 08:42 AM Share Posted 25/03/12 08:42 AM (edited) ...........Holy FARK Edited 25/03/12 08:42 AM by PAZZOnegger Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 4d Gender: Male Location: SE Melbourne Posted 25/03/12 09:01 AM Share Posted 25/03/12 09:01 AM (edited) 1.5mm pitch whats the diameter...I am going to guess M11Only because M10 die is too small and M12 die is too big. Don't have an M11Edit: had another look. Put an M10 tap into the gear knob and its a very snug fit but unfortunately its not long enough to hit the actual thread and don't want to get it stuck.The tip of the stick (first couple of threads) is a little larger than the rest so a M10 bolt probably wont go over it. I am starting to think it is M10 but dont have a vernier caliper to check. Edited 25/03/12 09:14 AM by Paulie2256 Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 29d Gender: Male Posted 25/03/12 09:08 AM Share Posted 25/03/12 09:08 AM Fark that vid pazz,, desintergrated the car Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 4d Gender: Male Posted 25/03/12 09:09 AM Share Posted 25/03/12 09:09 AM Yeah pretty sure that person saw there life flash before there eye's. Link to comment Share on other sites More sharing options...
