Vic Spotted & Chat Thread
geea
  • Member For: 14y 5m 29d
$50 says im not the only one gettin hammered this arvo
had my 1st at 10;30 am, had my last bout 20 mins ago !!!
  • Member For: 13y 11m 15d
XRTFG6 I had the motor built and snapped the auto input shaft again
Snapped twice! Hope it holds up for you this time, its good to see another fg out & about in the area might run into you again soon then
  • You've changed man....
  • Member For: 14y 29d
I got my work break up tomoz arvo, prob wont be in any shape to drive
also spotted a FG mkII xt eco lpi on the freeway this arvo.
staino who does the on site installing for your joint?
Myself and I have a couple of contractors when needed.
You want a job?
likes this
not this
Edited by sad panda
  • Member For: 19y 5m 14d
Why would it hold up any different if its being replaced with a new one.. What makes this new one any different to the last 2 that snapped?
Shannonp, is your ZF tuned?
I hear that yarra valley are upgrading the ZF inputshafts with larger diameter ones.. Really the only way of sorting out this well known problem. It does require modifications to the torque convertor as well.
If anyone actually compared the input shaft of the ZF vs the old 4 speed auto, You'd actually LAUGH!.. I'm sure my mums Mazda6 has a bigger input shaft than the ZF.
The 4 speed auto's input shaft is very close to the old C10 size shaft. You'll break a set of planterys before you break the input shaft in a 4speed. Unless your tune isn't upto spec, where you'll just chew out the Band, and loose 2nd/4th gear (4th gear will be noticable first).. Or alternatively, the C1 clutchpack, where you'll loose 3rd and 4th.
  • Pitlane Member
  • Member For: 17y 8m 24d
1.Kv/J.d
2.scottymadf6
3.Dillz
4.k31th *probably*
5. FG50T - If ford spare parts pulls through for me
6. paulie2256
7. TRA1NR - minus kebabs and hwy
8.
9.
10.
11.
12.
13.
14.
15.
