  • Member For: 21y 10d
I had a problem like this, my car would show lean by my meter,and it ended up being the tube on the fuel regulater, would leak air preasure out so it would lean my mixtures out, because of lower fuel preasure. it did not ever come off, so I put a ziptie around it and has been good ever since. I was blameing my fuel pump.
  • Replies 38
  • In Your Face
  • Member For: 22y 2m 28d
<{POST_SNAPBACK}>
Was that your origanal fuel reg.
  • Site protagonist
  • Member For: 22y 25d
  dswiders said:
Nizpro's change over Ford injectors for their drilled ones was $650 supply and fit.  They ship them off somewhere for them to be drilled out, but I don't know where.
Daniel
<{POST_SNAPBACK}>
$650 seems a bit steep to have drilled out injectors fitted. The cost of drilling would be minimal and its not a big job to fit them.
Geea. :spoton:
  • In Your Face
  geea said:
Daniel
<{POST_SNAPBACK}>
Geea. :pinch:
<{POST_SNAPBACK}>
It is a rip off :spoton:
  • fordxr5turbodotcom
  • Member For: 21y 7m 27d
what rwkws do Nizpro rate the 'drilled out' injectors to?
Do they flow better than 968s?
Guest fmitry
  • Guests
  geea said:
Daniel
<{POST_SNAPBACK}>
Geea. :laughing:
<{POST_SNAPBACK}>
If I was to by the injectors on sale by Eugene, what could I get for my stock injectors? I was quoted by a tuner $120 an injector to get them drilled.
  • Member For: 21y 9m 19d
  geea said:
Daniel
<{POST_SNAPBACK}>
Geea. :laughing:
<{POST_SNAPBACK}>
that's cheap I've been quoted $880 that's not even fitted :laughing:
  Blown BA said:
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
yes that was my standerd one. did not lean it out alot but if it was close to limit allready it could have urt something.
<{POST_SNAPBACK}>
Depends on how many holes have been drilled. The injectors I had only had 2 holes on opposite sides drilled out. They will flow enough full for 360 - 400 rwkw. Which would make them slightly larger than the 968's. You can then get the other 2 holes drilled as well if you want more power.
They perform well never had a problem with them. I think $650 is a bit steep considering its a change over situation and they only have to cover the cost to have them drilled and freight charges. It not a big job to change them over either. But at $90 an hour it does'nt take long for the total to add up.
macka
