  • In Your Face
  • Member For: 22y 2m 27d
there are other with eugenes injectors and have around 300 and are having no problem and they also have edit ..I need to know cause I am stepping in the injector area soon
<{POST_SNAPBACK}>
No Problems here from me :censored:
<{POST_SNAPBACK}>
Fark, so does this mean it's my car ?
<{POST_SNAPBACK}>
No Daniel it's not the car :kiss:
  • Replies 38
  • Member For: 21y 6m 10d
<{POST_SNAPBACK}>
No Problems here from me :spoton:
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
No Daniel it's not the car :nono:
<{POST_SNAPBACK}>
So if it's not the car, whats the problem then ?
Is it the way I drive ? :w00t2:
  • Member For: 20y 9m 17d
I've had my springs, injectors and edit all custom tuned by Nizpro about a month ago.  I had issues to fuel consumption, and more importantly, fuel mixtures  but found that it was the variation of Eugenes injectors as against the factory ones.  The computer kept on adjusting my fuel mixtures as it's constantly learning.  Whereas the guys that are running piggyback don't have a problem due to the signal bending.
Simon has looked into my issue,  one minute its running lean and another time it's running too rich.  The dyno day at Autotechnique had shown ance again that the car was running dangeriously lean where Mario had to back out of the dyno run at 227 rwkw.  Simon had tuned my car to 262rwkw.
My car has been back to Simon twice now,  each time when he's been adjusting my injectors, it's like running too lean and keeps on adjusting, then it gets to a point where it goes too rich.  So he backs off the mixture and then it's running too lean again.
Simon has invested a lot of time on my car trying to get it right.  Approx 11 hours on the dyno !  Yesterday he got it spoton except for the top end where it was running too rich.  Because of not knowing what the computer will do ( lean or rich ), I settled on replacing Eugenes injectors with Nizpro ones.
Results,  well I think that they speak for themselves...... 285 RWKW  :spoton:
I'd like to post up the dyno sheet, but I can't get the  :ermm:  scanner to work.
But thanks to my brilliant partner, she suggested that I use the digital camera  :spoton:
<{POST_SNAPBACK}>
just wondering. I havent touched my car from stock but getting interested. how much has this cost you ( injectors, labour, anything else needed to do these mods). I would be intesrested in getting nizpro injectors but have no idea about modifying these cars.
  • Member For: 20y 3m 11d
Can you just get Nizpro injectors ? Will they do a swap and some cash on top for your current injectors for there drilled out ones ?
Who actually drills out injectors ?
  • In Your Face
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
No Daniel it's not the car :ermm:
<{POST_SNAPBACK}>
Is it the way I drive ? :ermm:
<{POST_SNAPBACK}>
Well that could be part of your problem :spoton:
  • Member For: 20y 3m 24d
Those injectors are very cheap compared to the other alternatives on the market. Perhaps the quality just isn't good enough to deliver the type of performance required. Which is no way any fault of Eugene's, after all he's just relaying the info he's been given.
But it could be a possibility...
<{POST_SNAPBACK}>
Cheap is fine by me, they do a fantastic job.. the only thing that has a problem with them are my tires :spoton:
  • Member For: 20y 10m 2d
After looking at the dyno graph, peak power's pretty much made at 2700rpm! What's stoping the power production from then on? exhaust? intercooler? It looks like there's plenty of room to improve on the 285rwkw's given how quickly it's made. I'm interested because I've been considering the same same kit, but am not in any rush to modify just yet
  • Lemming No #5
  • Member For: 20y 6m 12d
<{POST_SNAPBACK}>
Perhaps you should look at the graph again.
At 2700 rpm the car is making about 260 RWKW a full 25 KW short of peak power, which I might add is made at about 4600 rpm by the looks of things
  • - Track Bound EVO III -
  • Member For: 20y 5m 20d
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
He did say "pretty much", so I'd go with "nearly "....
what's stopping it?? fuel pump, conrods, transmission, intercooler, exhaust.... etc etc etc..... just the expensive stuff.
Cheap to get that far, then go fertilize the money tree.....
Nizpro's change over Ford injectors for their drilled ones was $650 supply and fit. They ship them off somewhere for them to be drilled out, but I don't know where.
To improve the car any further I need to :-
1st Strengthen :spoton: the SSS - a must
2nd Larger Intercooler with spray kit like this guy :laughing:
3nd Exhaust :smilielol:
But then again, I'm happy with the 285Rwkw, will probably take it easy for a while and wait for my tax return before doing the Auto upgrade.
Any one after a set of Eugenes Injectors ? PM me and give me your contact details.
Daniel
