Lightning Member 335 Member For: 22y 3m 7d Location: Perth, Western Australia Posted 16/04/05 08:25 AM Share Posted 16/04/05 08:25 AM Guys,I'm new at adding an image to a post, so hope this goes okay...Anyway, I was adding some water to the coolant bottle the other day and I noticed what looks to me like a splice in a metal tube where someone's added in a bit of hose with a couple of hose clamps. See red circled area in the first image: In the 2nd image, you can see where it appears that whatever's running through this pipe has pissed all over the thingy underneath it at some time (sorry, I'm not a mechanic!).Can someone who has a T tell me if this is normal, if not what the tubing is for and if you reckon I should do something about it.Simon.... Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/ Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 11m 29d Gender: Male Location: Brisbane Posted 16/04/05 08:37 AM Share Posted 16/04/05 08:37 AM I think that’s normal, but it looks like the rubber is split and sprayed coolant over your aircon compressor and the refrigerant pipe – should be a warranty fix.Trent. Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242971 Share on other sites More sharing options...
AWW XR6T UTE Member 129 Member For: 21y 11m 17d Location: Brisbane Posted 16/04/05 08:39 AM Share Posted 16/04/05 08:39 AM That join is normal.The leak on the Air Con compressor is probably not from that join, but from the black pipe that goes into the thermosat housing below the radiator tube. Mine did this & was fixed under warranty, usually a small drip when it gets hot, I think they pulled the tube out & just put some sealant around it, and presto, no more leak on the A/C. Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242972 Share on other sites More sharing options...
Lightning Member 335 Member For: 22y 3m 7d Location: Perth, Western Australia Posted 16/04/05 08:52 AM Author Share Posted 16/04/05 08:52 AM Thanks guys, particularly that the join is 'normal', but a couple of responses:1) Check this photo, it looks like the same colour of discharge etc:2) I dipped my finger in the hollows circled in the image below and it feels like oil:I'll think get the dealer to have a look at it. My oil level, coolant level and brake fluid levels are low anyway.Simon.... Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242976 Share on other sites More sharing options...
Lightning Member 335 Member For: 22y 3m 7d Location: Perth, Western Australia Posted 16/04/05 08:53 AM Author Share Posted 16/04/05 08:53 AM PS: First time I've used a $2500 camera to take photo's of a pipe under my bonnet, let alone Photoshop to edit it! Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242977 Share on other sites More sharing options...
1axr TEAM BLUEPRINT Member 913 Member For: 22y 2m 19d Location: Perth W.A. Posted 16/04/05 09:11 AM Share Posted 16/04/05 09:11 AM lightningyou did well with your posts now get you car to the dealers and get it fixed before you loose all your coolant and you sieze your motor. Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242981 Share on other sites More sharing options...
Lightning Member 335 Member For: 22y 3m 7d Location: Perth, Western Australia Posted 16/04/05 09:18 AM Author Share Posted 16/04/05 09:18 AM 1axr said: you did well with your posts now get you car to the dealers and get it fixed before you loose all your coolant and you sieze your motor.Yes, Dad It's going in on Monday for something else anyway.Lightning.... Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242985 Share on other sites More sharing options...
1axr TEAM BLUEPRINT Member 913 Member For: 22y 2m 19d Location: Perth W.A. Posted 16/04/05 09:20 AM Share Posted 16/04/05 09:20 AM I'm probley old enough to be your dad.us sandgroppers have to stick together. Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242987 Share on other sites More sharing options...
Lightning Member 335 Member For: 22y 3m 7d Location: Perth, Western Australia Posted 16/04/05 09:28 AM Author Share Posted 16/04/05 09:28 AM Doubt it :-) Unless you're in your mid-50's, that is! Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242989 Share on other sites More sharing options...
cikas Team HgAg Member 616 Member For: 20y 5m 18d Location: Rockingham W.A Posted 16/04/05 10:03 AM Share Posted 16/04/05 10:03 AM Hey LighntingI had the same prob man. Take it to ford and they fix it.. Get them to do a proper job though. Mines been back 4 times for the same leak.. But its usualy only in there for half hr.Longest was 4 hrs which was the last time when they replaced all the hose's / O Rings and all the clips and for some reason replaced my radiator too.. Had to get the parts in from Perth..cheers cikas Link to comment https://www.fordxr6turbo.com/forum/topic/16984-weird-tubing-on-my-t/#findComment-242991 Share on other sites More sharing options...
