filpee Member 20 Member For: 18y 5m 18d Location: Perth Posted 27/10/06 11:52 PM Share Posted 27/10/06 11:52 PM auMatt said: Hey Filpee, you should have asked as I could have sold you the board less parts (or with parts to suit) for the drivers side switch.MattThanks auMatt but I liked the challenge of doing it myself.Heres a pic of the final product. I probably should have sleeved the wires between the LED's and the resistors but I dont think I'll have any problems.I hope to upgrade the drivers side switch to a sedan version in the near future anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/16944-window-switch-illumination/page/9/#findComment-455667 Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 19y 10m 13d Gender: Male Location: Melbourne Posted 28/10/06 12:36 AM Share Posted 28/10/06 12:36 AM Nice work. The laquer is very strong so you shouldnt have any problems with shorting on the un protected wire. What colour leds did you use? I have 440nm wavelength 3mm leds here which are the same colour as used by ford if you want some let me know.Matt Link to comment https://www.fordxr6turbo.com/forum/topic/16944-window-switch-illumination/page/9/#findComment-455682 Share on other sites More sharing options...
mook05 Member 108 Member For: 21y 10m 5d Gender: Male Location: Melbourne Posted 28/10/06 12:44 AM Share Posted 28/10/06 12:44 AM I have wanted to get these done for ages now, but never got around to it. A little while ago the drivers side switch started playing up, so I was glad I didnt get it modded as it would have voided warranty on the switch. I had the drivers side switch unit replaced under warranty - imagine my surprise when I turned the lights on that night and the switch lit up! I'm wondering if the unlit switches are no longer stocked - I think all the BF's are now illuminated? Now I just need to change out the other 3 doors. They might not be blue (they light up white) but much better than no lights at all!Mook.. Link to comment https://www.fordxr6turbo.com/forum/topic/16944-window-switch-illumination/page/9/#findComment-455685 Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 19y 10m 13d Gender: Male Location: Melbourne Posted 28/10/06 12:48 AM Share Posted 28/10/06 12:48 AM Ford still stocks non illuminated switches. There was at one stage when all XR's were getting illuminated switches. But it looks like they have stopped doing it again from what I have been hearing. If you want them done in blue let me know.Matt Link to comment https://www.fordxr6turbo.com/forum/topic/16944-window-switch-illumination/page/9/#findComment-455688 Share on other sites More sharing options...
mook05 Member 108 Member For: 21y 10m 5d Gender: Male Location: Melbourne Posted 28/10/06 01:44 AM Share Posted 28/10/06 01:44 AM No worries thanks MattMook Link to comment https://www.fordxr6turbo.com/forum/topic/16944-window-switch-illumination/page/9/#findComment-455704 Share on other sites More sharing options...
filpee Member 20 Member For: 18y 5m 18d Location: Perth Posted 28/10/06 05:24 AM Share Posted 28/10/06 05:24 AM auMatt said: Nice work. The laquer is very strong so you shouldnt have any problems with shorting on the un protected wire. What colour leds did you use? I have 440nm wavelength 3mm leds here which are the same colour as used by ford if you want some let me know.Matt←I stopped by Altronics and picked up these ones http://www.altronics.com.au/index.asp?area=item&id=Z0707mm Blue LED Water ClearSpecifications:Viewing Angle: 22°Brightness: 1400mcdVoltage Typical: 3.5VVoltage Max: 4.0VCurrent: 30mACurrent Peak: 150mAnothing that interesting but does the jobThose LED's you have sound interesting. I was thinking now I might put a couple of em under the cci fascia to light up the tissue box and then a couple more under the tissue box to light up in there.Then to finish up ill look at putting a couple of cold cathodes up under the drivers side dash and the passenger dash to light up the footwells. Link to comment https://www.fordxr6turbo.com/forum/topic/16944-window-switch-illumination/page/9/#findComment-455783 Share on other sites More sharing options...
