Project Xr6t
SPIKO
  • Toughest BA Turbo
  • Member For: 22y 2m 12d
Things break along they way; you replace them with stronger items.
Give Spiro time : he'll get there.
Brian
  • Replies 111
Posted Images
  • Site protagonist
  • Member For: 21y 9m 24d
I think Spiro was using a YarraValley Auto Box. Probably best for Spiro himself to confirm this. It's going to need a special box to cope with his power.
Geea. :kissmy:
  • Toughest BA Turbo
Spiro is running beyond the recommended torque limit of that modded box.
As I've said before, we push the limits, and things break.
It was not unexpected. Spiko will address that issue, plus other issues that he'll soon find with the power level he wants to run. I'm going through the same loop.
Brian
  • Toughest BA Turbo
Adam,
There's a bit more to it.
Spiko uses the car a daily driver also, not a dedicated drag car, possibly why the hope of the 4-speed holding together.
No doubt Spiko is currently reviewing the situation.
The other problem/issue up here is that as soon as you break 11s you need a roll cage..... and no, we don't really want to move to Melbourne.
Brian
  • Wanabe mechanical engineer
  • Member For: 20y 5m 19d
Adam,
Brian
So he is hoping for a single 9 second pass and then say "yep, done that, don't want a cage"?
If so, then lmao.... He should use a G-tech or something to practice first :P:kissmy:
Guest xrtwpn
  • Guests
Adam,
Brian
<{POST_SNAPBACK}>
You need a roll cage anywhere you go now and if he runs 140mph which he will need to to get a 9 he will also need a shute on the back
Going to be hard to get one of these cars to run 9's and be a daily driver
But good luck
  • Toughest BA Turbo
Adam,
Brian
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Spiko is a very experienced drag racer.
When does a full pass it'll be such that he wants to shatter whatever the record is at that time, and he's setting the car up to do it.
He is one very determined person, and I hope his patience is rewarded.
Brian
