tig Donating Members 735 Member For: 17y 10m Gender: Male Location: kenthurst, Sydney Posted 21/11/08 09:47 AM Share Posted 21/11/08 09:47 AM Going to sell my BA but need to replace bonnet release as it has broken. Looks reasonably straight forward at first glance. Has anyone fitted one and are there any tricks to connecting and adjusting. The other option I see would be to repair the existing one. Would rather have it done right as somebody here might end up with it.Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-772675 Share on other sites More sharing options...
philbaxr6t Member 102 Member For: 16y 8m 29d Gender: Male Location: nor perth Posted 21/11/08 10:01 AM Share Posted 21/11/08 10:01 AM um had to do one at work recently!! first thing to check is that its actually the handle as the handles clips to the bottom of the fuse box and the fuse box actually brakes sometimes so check that first if its the fuse box theyre easy as about 5 screws and 5 plugs um if its the cable theyre a little tricky coz the cable runs through the inner cuard liner on the driver side but they arnt adjustable they just clip on both ends p.s the fuse box brand new is bout 65 buck the cable is bout 30 ebay is your best bet for the parts if your not in a hurry hope this helps have a good one Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-772678 Share on other sites More sharing options...
crazed1 Member 105 Member For: 19y 6m 10d Location: Sydney Posted 21/11/08 11:32 AM Share Posted 21/11/08 11:32 AM I have to change mine, its broken in the handle end cause its a crappy plastic lever but the spare part is modified with some metal piece instead.The Ford guy said to pull out the grill and piece of scuttle over the radiator, remove the inner guard enough to move you hands around, I think he said to tie the new one to the old one to pull it through. If I get a chance on the weekend ill do it and post a how to do here. Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-772712 Share on other sites More sharing options...
tig Donating Members 735 Member For: 17y 10m Gender: Male Location: kenthurst, Sydney Posted 22/11/08 08:05 AM Share Posted 22/11/08 08:05 AM Thanks fellas, will give it a go this week. Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-773086 Share on other sites More sharing options...
MaTTe Member 143 Member For: 16y 7m 3d Location: Perth Posted 22/11/08 08:54 AM Share Posted 22/11/08 08:54 AM they've redesigned the handle, so that it grips differently. mine broke the handle and the fuse box.get one of the new release handles, and see if you can just take the ball knuckle out of the old handle and put it into the new handle and you wont have to replace the cable. If not, you're probaby better off pulling the front quarter panel off as its not hard, and it'll make the job easier Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-773105 Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 17y 1m 23d Gender: Male Location: New Zealand, Palmerston North Posted 23/11/08 07:49 AM Share Posted 23/11/08 07:49 AM mine broke ages ago... had used a few well placed cable ties until earlier today where it broke again... pliers are the way now Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-773507 Share on other sites More sharing options...
tig Donating Members 735 Member For: 17y 10m Gender: Male Location: kenthurst, Sydney Posted 23/11/08 08:01 AM Share Posted 23/11/08 08:01 AM Matte, thanks for that, I will see if the new handle will fit on the old knuckle.cheers Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-773516 Share on other sites More sharing options...
scar Donating Members 177 Member For: 17y 9m 25d Posted 31/12/08 07:51 AM Share Posted 31/12/08 07:51 AM Just a bump to let everyone know the cost of these at Coventrys is $40, it is an upgraded unit, compared to the BA assemblies and takes near on an hour to install. Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-794042 Share on other sites More sharing options...
MaTTe Member 143 Member For: 16y 7m 3d Location: Perth Posted 31/12/08 09:22 AM Share Posted 31/12/08 09:22 AM why does it take so long to install? an hour seems like ages to install something seemingly so simple..I have only seen photos of the new unit, so im not 100% sure of the mounting points but im guessing from what you've said that you need to remove a few things to mount it. Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-794061 Share on other sites More sharing options...
scar Donating Members 177 Member For: 17y 9m 25d Posted 01/01/09 01:44 AM Share Posted 01/01/09 01:44 AM To do the job proper, you need to remove the front quarter panel, the front grill , one of the overhead radiator supports and the actual locking mechanism. You need to unclip the old cable and then feed the new cable in the support clips, and obviously take a bit of care so as to not chip any of your panels and realign once fitting. So I reckon an hour is what it will take the average joe with his basic socket set, the more savvy will get it quicker. Link to comment https://www.fordxr6turbo.com/forum/topic/16753-bonnet-release-merged-topic/page/7/#findComment-794160 Share on other sites More sharing options...
