Pwr Intercooler
saleen
  • Big Gun
  • Member For: 22y 4m 14d
No before and after figures as yet. I did mention before that there was not power increase in normal conditions, but I have notice when the weather is cooler, the power increase is greater than before. As also stated previously, I wasn't looking for a power gain, just consistency through different ambient temperatures. I have a feeling I might pick up a neddy or 2 when I fix that upper hose, as it's kinked like a *beep*. For diameters of hosing required, It's in this thread somewhere, but the length is at leat 12cm long. As for where to get the hosing from, I'm not sure as I'm waiting for payday to go on another spending spree. So if anyone knows where to get this stuff from, could you please advise.
Rob
  • Replies 49
Posted Images
  • Member For: 20y 8m 29d
Yes on mine I used 2x 45 degree bends and a foot of straight pipe (2.5 inch), also a reducer (2.5 to 2.25) all in stainless, then I used the standard rubber pipe up to the crossover. that way it all looks stock, and it is a lot better flow than standed, the stainless pipe goes from the intercooler, under the light, under the battrey, onto the rubber pipe. I also had to weld apeace of 1/2 inch pipe on to the pipe to hook up the preasure sencer, behind the light. hope this helps.
  • 4 weeks later...
  • Formerly Turbo6
  • Member For: 22y 1m 17d
After reading how you guys did this, I too took the plunge with a mate of mine and shoe horned one of these intercoolers into the ute on Saturday morning. You're right, what a mission! It certainly is not a simple bolt-in replacement.
After driving the car a few hundred kms to go riding on Sunday, it does feel a little stronger now. However, it is booked in with Lachlan back at Chiptorque Thursday afternoon for a retune.
One thing I have noticed is that it is running a little hotter then it used to. The new 'cooler does take up an awful lot of space so this is understandable. I have ordered a cooler thermostat from BPT to try to combat this a little.
I will post the re-tune results after Thursday. :spoton:
  • Member For: 19y 11m 1d
I am new to Turbos - so a couple of questions more than anything else:
Surely as the factory intercooler is below the front structure of the body (as show in the build photos) and the replacement one is partially shrouded by the body - wouldnt that part of the intercooler be fairly ineffective at least for cooling purposes?
Is it that the Intercooler is larger - so more air can flow through it with less restriction rather than the amount of cooling surface available that can potentially give more power?
Also the comment re getting a cooler theromstat - that wont really help will it? The car should be trying to stay at the thermostat level all the time, if it is running hotter wouldnt this suggest it cant cool the car with the thermosatat working properly? This would suggest to me that you need either an additional fan, or some other way of getting more air through the radiator?
  • Formerly Turbo6
Intercoolers work mostly through thermal efficiency, the greater the "mass" so to speak, the more efficient the cooling job. Although, flow through the intercooler is critical and the PWR 'cooler is much more efficient then the standard one. For higher boost levels, it is even more efficient - hence the law of diminishing returns (the opposite here). Like saleen said, I didn't do this for more power but rather consistent power on hot days. If I pick up some neddies along the way then it really is a bonus. With the more efficient 'cooler, it just means that the turbo now does not have to work so hard to push the same amount of air through - hence, less heat, more bang.
With the thermostat, instead of opening at some 93 degrees, I am getting one that opens at I think, 87 degrees. This effectively helps with reducing heat soak. If the heat can start to be dissipated earlier, it effectively helps lower the maximum temp reached by the cooling system. I hope this makes sense? If you need a practical example of this, simply remove your thermstat from your car and go for a drive. You will be amazed at how cold it runs - it will never get to operating temperature which is very bad for your car. The standard cooling system is very effective, but not as much so when you block the flow with a new intercooler. :spoton: So with a new thermostat that opens at a lower temp, this will help the motor run cooler and avoid heat soak. Trust me, it does work. :spoton:
  • Big Gun
Well done Turbo6. I have notice my car runs a bit hotter going up steep mountains but actually runs cooler(very close to the first notch) on steady cruising. I've just done a 3800km trip from NSW South Coast - Deniliquin - Melbourne - Adelaide - Mildura - Back to Deni, and the engine temperature was perfect the whole time.
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 8m 2d
How did the dinosaur hold up hope did'nt go into limp mode to often :ermm:
CYA JEFF :spoton:
PS:And im not talking about the strap on :spoton:
  • Big Gun
CYA JEFF :spoton:
The dinosaur held up just fine. Small brush with the law, but she(yes, SHE) let me off. Good old Blueprint still attracts fair bit of attention. Not like these new age 'lightning strike......WTF' colours that were designed by poofs FOR poofs.
Heres a pic of the cooler awaiting the new custom grill being made. This photo was taken out in the middle of nowhere, just up the road from f#*k all earlier his evening.
Love your work good to see ya back :spoton::spoton:
  • Formerly Turbo6
saleen, same goes for the temp on steady cruise mate.
I went to Autobarn yesterday and picked up a thermostat that opens at 82 degrees instead of the standard 93 (I think). I will put it in today and drive the car to the Gold Coast and around for work tomorrow (retune tomorrow arvo at ChipTorque) so will report back on the running temp after that mod. It should work an absolute treat..... :laughing:
