Progress Update: How Is BCL's Car Going?
PASHEN
  • Replies 510
  • Artificially Aspirated
  • Member For: 21y 2m
Tell us a bit about the STI?
<{POST_SNAPBACK}>
What is your best ¼ mile time now in the STi? makes around 220-230kw @ wheels correct?
He has a Version 6 STi with the 2.5ltr STi engine convertion among some other "upgrades" he will have to post them down. I have forgotten.
Edit: I read in your sig 12.3... Is that still the current best time? How is your car up top end from a roll?
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 21y 11m 23d
Even with 360rwkw I don't think my Ford T will keep up with my STi, so I'll give the Ford some more grunt.
Brian
Tell you what Brian, I'll be more than happy to help you compare? I'll volunteer (if I have to) to drive one or the other... :blush:
I'm not picky :nuts:
GIMME GIMME GIMME :o
  • Toughest BA Turbo
  • Member For: 22y 2m 14d
<{POST_SNAPBACK}>
For those that don’t want to read about my Sti, please leave now (sorry).
I bought a new 2000 Version 6 model Sti (stock it was $62k+orc), with 2 Litre motor.
Various upgrades over 4 years; 3 different turbos tested.
2.5 litre STi motor upgrade late last year.
Car now has:
• Forged pistons
• Apexi Power FC ecu
• Apexi AX5 turbo with P20 exhaust housing
• 4” exhaust from Tuffy (same as my Ford T) into dual 3” pipes and mufflers
• Turbosmart 48 mm external wastegate
• 850cc Sard injectors
• Sard rising rate regulator
• APS front mount Intercooler
• Zerosports extractors
• Blitz Electronic Boost controller
• DMS adjustable (height & damper settings) suspension
• B_technic 4-pot calipers
For comparison I have the dynograph from 6/12/99 on the same CRD dyno, from when my STi V6 was near brand new.
Stock STi max
112kw at 145kph, and 3100N at 110kph.
Now it's
232kw at 135kph, and 6800N at 110kph.
Note: these power figures are AT ALL 4 WHEELS, and car only weighs 1260kw.
So, maximum power is made at fewer revs, and maximum torque at same revs as the original 2 litre Sti.
At the point of maximum power I'm running 20lb boost, down from the max boost of 22lb at 105kph (4000revs).
Lower in the revs, at just 80kph in 4th:
Stock STi had 36kw and 1700N tractive effort
New 2.5L has 77kw and 3400N tractive effort
So low down torque starts from a higher base, making driving far easier in the 2.5L. The tractive effort at this low revs is more than the stock STi made at it's peak.
At 100kph in 4th:
Stock STi had 84kw and 3000N tractive effort
New 2.5L has 162kw and 5200N tractive effort
So new power hits very hard between 80kph and 100kph (3000 to 3800 revs).
I don't know how much the dyno calibration has changed since then, and whether or not the runs are comparable.
Note that the turbo I have is actually a bit too small; it makes for a great street car.
I could use a larger turbo and probably get 300rwkw if my objective was drag racing. There’s still plenty of potential.
I’ve only run it once at the drags, did a 12.3 (Geea did 12.2) on a very hot night; I was running 37lb pressure in the tyres. On a cooler night around 11.7 is likely.
When I drive my wifes my03 rex (similar performance to a stock Ford) it feels like a slug.
The STi will pull 4th gear from 1000 revs; low down torque is unbelievable good.
Launching, it's easy to spin all 4 wheels.
Check out the dyno graph below.
And the handling; just fantastic.
Brian
Guest xrtwpn
  • Guests
Brian
That is an impressive dyno graph power comes on really hard. Most of the graphs I have seen on here from the xr6 turbos look really lazy and die top end with boost dropping away and the top end of the power run goes flat
When I get my car is back on the road ill post some graphs of the way the power climbs in my xr6t it's very similar to your STI with no flat line at the top or boost dropping away
  • Mal Wood Automotive
  • Member For: 22y 4m 3d
The last I heard there were clutch issues at around 500rwkw.
<{POST_SNAPBACK}>
The clutch is rated at over1200ftlbs. I guarantee that there are no clutch issues. There might have been issues with the apprentice who fitted it incorrectly last time and damaged it, (as can happen when anything mechanical is incorrectly fitted). As the unit in question had an unconditional warranty, I am sure we would have heard if there was a problem. Ben.
  • 2 weeks later...
  • Toughest BA Turbo
An update.
Simon at Nizpro has got the car back together and on the dyno today.
ref http://forums.nizpro.com.au/phpbb/viewtopic.php?t=491
"Hi all just stopping for lunch so finally I'll give you an update on Brian's car. 502 rwkw on 20 psi @ 6500 rpm on Mobil 8000 pulp, and still more to come,. Hopefully I'll have some even bigger numbers after lunch."
Note: This is using 5th gear, as his dyno has trouble holding the torque in 4th gear.
Brian
