bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 2m 14d Gender: Male Location: Sydney Posted 22/03/05 06:52 PM Share Posted 22/03/05 06:52 PM Are you planning on running it down the quarter when its done?<{POST_SNAPBACK}>Yes I'll give it a go.Brian Link to comment Share on other sites More sharing options...
Bain Member 827 Member For: 20y 10d Gender: Male Location: Melbourne Posted 22/03/05 08:56 PM Share Posted 22/03/05 08:56 PM Sounds awsome!Have you thought about any rear end body work? Shorting the rear axles and cutting out some of the inner boot to put in fatter tyres? (for more traction?)Is it meant to be a daily driver or just a pure track car? Link to comment Share on other sites More sharing options...
dazza1981 Member 45 Member For: 21y 7m Gender: Male Location: Brisbane Posted 22/03/05 09:35 PM Share Posted 22/03/05 09:35 PM Thanks Dave.2x2 weeks.I haven't seen the car for 5 months.I drive 3 other turbo cars during the week, otherwise I'd be screaming… I’m patient and see this as an R&D process.New Stage 5 Nizpro motor with forged crank, Nizpro cams, forged rods and pistons are in the car; new motor has been run in. Also 1000+ cc injectors; special coil packs, Motec with cam & other options (e.g traction control); Nizpro extractors; 3 fuel pumps; external wastegate; huge turbo; new Intercooler, 8000 rev tacho (fpv); whole inlet system upgraded to around 5” piping (except Nizpro plenum and throttle body). ... retain Mal Wood 6-speed & 4" exhaust.Early testing indicated around 500rwkw at just 1.1 bar (as a guide).Car will rev to 7500 revs.I will be able to control boost via a potentiometer attached to the MotecOutstanding:New triple plate Os Giken clutch yet to go, new mufflers, review of inlet system to check for bottlenecks, more tuning... see what breaks. ... tyres & new bonnet???Not sure about retaining 4.10 diff … will test the car first.I'll provide an update soon. Just don’t ask how much I’ve spent …. A ‘pretty penny’ is the response you’ll get.That’s it for now.Brian<{POST_SNAPBACK}>that's amazing ! Cant wait to see the end result Link to comment Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 20y 10m 17d Gender: Male Location: who knows Posted 22/03/05 10:48 PM Share Posted 22/03/05 10:48 PM well done brian I envy your mods ....jeff Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 8m 11d Posted 22/03/05 11:14 PM Share Posted 22/03/05 11:14 PM Well done Brian,Most likely traction will be the biggest enemy to performance. Tubbing out for bigger rear tyres seems like a distinct possibility.I cannot wait to hear how the project turns out. Cheers Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 2m 23d Gender: Male Location: Strapped in and holding on Posted 23/03/05 12:39 AM Share Posted 23/03/05 12:39 AM I thought you were getting serious with it this time..................I can understand where you are coming from though, I wouldn't be happy with 360rwkw either.. Link to comment Share on other sites More sharing options...
Guest xrtwpn Guests Posted 23/03/05 02:17 AM Share Posted 23/03/05 02:17 AM Brian whats the most power you will be able to run on pump fuel ?500rwkw is alot of power for a track car considering v8 supercars only make around 360rwkwIt's too much power for a street car to use on a track only good for 1/4 Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 2m 15d Gender: Male Location: Brisbane Posted 23/03/05 02:26 AM Share Posted 23/03/05 02:26 AM Brian whats the most power you will be able to run on pump fuel ?500rwkw is alot of power for a track car considering v8 supercars only make around 360rwkwIt's too much power for a street car to use on a track only good for 1/4<{POST_SNAPBACK}>Are you sure about V8 Supercars only making around 360rwkw?? That works out to be about 482BHP. I thought that most V8 Supercar teams were quoting 620bhp which is more like 470rwkw. Link to comment Share on other sites More sharing options...
Guest xrtwpn Guests Posted 23/03/05 02:42 AM Share Posted 23/03/05 02:42 AM Brian whats the most power you will be able to run on pump fuel ?500rwkw is alot of power for a track car considering v8 supercars only make around 360rwkwIt's too much power for a street car to use on a track only good for 1/4<{POST_SNAPBACK}>Are you sure about V8 Supercars only making around 360rwkw?? That works out to be about 482BHP. I thought that most V8 Supercar teams were quoting 620bhp which is more like 470rwkw. <{POST_SNAPBACK}>I saw the HRT cars on Starr performance's dyno last yeah and they made around the 360rwkw mark Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 2m 14d Gender: Male Location: Sydney Posted 23/03/05 02:43 AM Share Posted 23/03/05 02:43 AM Brian whats the most power you will be able to run on pump fuel ?500rwkw is alot of power for a track car considering v8 supercars only make around 360rwkwIt's too much power for a street car to use on a track only good for 1/4<{POST_SNAPBACK}>Adam,Still a lot of testing to be done, and too early to answer regarding fuel.I don't particularly want to run MB as a permanent additive (but I know of guys who do) or octane supplement. The car is for street use, and will be limited to 3 days per week, depending on what cars I have available at the time.I don't know yet how much more power is possible, say if I turn the boost up to around 1.7 bar. This Nizpro testing run in December with their motor (of very similar configuration) used a 50:50 mixture of Mobil 8000 and avgas to get over 1200HP and 1476NM of torque at 1.7bar. Remember these cars are very heavy... when weighed at WSID my car was around 1840kg (without me) ... supercars are a lot lighter, I think around 1350-1400kg, and I believe they have 400-450rwkw.I can turn the power down, as required, as many of my turbo cars in the past have run EBC's.Even with 360rwkw I don't think my Ford T will keep up with my STi, so I'll give the Ford some more grunt. Brian Link to comment Share on other sites More sharing options...
