XR_Jet Member 69 Member For: 18y 11m 6d Location: South of the Border Posted 28/04/06 02:54 AM Share Posted 28/04/06 02:54 AM Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 2m 14d Gender: Male Location: Sydney Posted 10/05/06 06:43 AM Share Posted 10/05/06 06:43 AM An update: Car was started last week, after some effort re-establishing wiring connections with wires that had been cut because of the Motec install.Motec is now removed, and Edit installed.Initial testing is without cam control and using the small Nizpro drilled injectors.It makes 350rwkw at 7lb boost, and 480rwkw at 17lb currently, and that has been without much tuning effort.Independent variable cam timing work is still in progress, and I won’t comment on current issues in that matter, as they are being addressed now.Big injectors will be installed next week, then boost will be further increased and we’ll see how well the Edit copes with higher boost.The starting and idle problems associated with the Motec have gone, which is very good news…. Another 2 weeks???Brian Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 3m 7d Gender: Male Location: SoR, WA Posted 10/05/06 06:46 AM Share Posted 10/05/06 06:46 AM An update: Car was started last week, after some effort re-establishing wiring connections with wires that had been cut because of the Motec install.Motec is now removed, and Edit installed.Initial testing is without cam control and using the small Nizpro drilled injectors.It makes 350rwkw at 7lb boost, and 480rwkw at 17lb currently, and that has been without much tuning effort.Independent variable cam timing work is still in progress, and I won’t comment on current issues in that matter, as they are being addressed now.Big injectors will be installed next week, then boost will be further increased and we’ll see how well the Edit copes with higher boost.The starting and idle problems associated with the Motec have gone, which is very good news…. Another 2 weeks???Brian←Awesome results for a mild aplication Link to comment Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 22y 2m 2d Location: North Brisbane Posted 10/05/06 06:59 AM Share Posted 10/05/06 06:59 AM Geez Brian. How can the thing make that much power at only 7psi !! Or 17psi for that matter!!Crikey. Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 2m 14d Gender: Male Location: Sydney Posted 10/05/06 07:14 AM Share Posted 10/05/06 07:14 AM Geez Brian. How can the thing make that much power at only 7psi !! Or 17psi for that matter!!Crikey.←Pretty big turbo, with big compressor compared to stock to flow more air, very good exhaust flow out of extractors and larger exhaust housing, plus motor blueprinted and well put together.Note that this motor uses lower compression, around 8.3 to 1, instead of 8.7 to 1, which means it's actually a better result than it appears. I.e 17psi is probably closer to an effective 15.5lb boost with standard compression.Brian Link to comment Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 8m 18d Location: Canberra Posted 10/05/06 07:59 AM Share Posted 10/05/06 07:59 AM holy fark what a beast! Link to comment Share on other sites More sharing options...
G6ET8U Playing with Sports Bikes... Silver Donating Members 1,927 Member For: 19y 4m 9d Gender: Male Location: Whistling, GTX. Posted 10/05/06 10:24 AM Share Posted 10/05/06 10:24 AM Good stuff Brian... It's starting to come together now!!! Mine is going in for a the injectors/valve springs and I'm picking up a T56 for it on Saturday... I'm not too far behind you now... NOT! Jack Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 12d Gender: Male Location: Victoria Posted 10/05/06 10:35 AM Share Posted 10/05/06 10:35 AM Hello...Straight onto the T56. What happened to waiting and saving a bit? Link to comment Share on other sites More sharing options...
G6ET8U Playing with Sports Bikes... Silver Donating Members 1,927 Member For: 19y 4m 9d Gender: Male Location: Whistling, GTX. Posted 10/05/06 11:35 AM Share Posted 10/05/06 11:35 AM Hello...Straight onto the T56. What happened to waiting and saving a bit?I've been offered a deal that I can't (and won't) refuse...Jack Link to comment Share on other sites More sharing options...
Xtreme F6 Team Xtreme Donating Members 1,680 Member For: 20y 1m 2d Gender: Male Location: Perth Posted 10/05/06 11:48 AM Share Posted 10/05/06 11:48 AM Geez Brian. How can the thing make that much power at only 7psi !! Or 17psi for that matter!!Crikey.←The NIZPRO exhaust manifold is a work of art, Along with Brians orsm turbo..... Hello! you have big power with little boost... Link to comment Share on other sites More sharing options...
