Ssl King Springs In The Back
XtRmn8
  • Replies 20
  • 570Nm @1800rpm
  • Member For: 21y 5m 17d
JB there is no need to cut down the bump-stops, as they are designed to become part of progressive springing in these cars. :censored:
I both agree and disagree with you on that! I do believe that the bump stops are designed to work with the progressive spring rate. But you have to take into consideration that before the car is lowered there is at least 25mm clearance between the suspension arm and the bump stop.
Due to this being the case from the factory, I am lead to believe that the clearance is necessary in order for the shocks to do their job. If you look at the pics below with SSL springs in the back of my car and about half a tank of fuel, the lower suspension arms sit up against the bumps stops and thus most of the suspension travel is absorbed buy the rubber stops rather then the shocks.
The BA that I had a look at on Sunday was lowered by Ford mechanics, who cut the bump stops at the red line. I am going to cut mine at the yellow line to give some clearance, about 20mm.
With the car riding on the bump stops with no people in it, imagine what it would be like with two people in the back! I am sure that the back suspension was not designed to work by riding on the bump stops at all times, which is why all factory cars have the clearance there!!
Cheers! :nono:
Click to enlarge!
The stuff running down the suspension arm is just me going silly with a can of silicon lube! :nono:
  • Member For: 21y 4m 8d
JB there is no need to cut down the bump-stops, as they are designed to become part of progressive springing in these cars. :sleepystuff:
<{POST_SNAPBACK}>
Cheers! :clap:
Click to enlarge!
The stuff running down the suspension arm is just me going silly with a can of silicon lube! :clap:
<{POST_SNAPBACK}>
Yeah that's where I cut mine, at the yellow line.
Thought I'd take this opportunity to show off the car aswell :P
http://blazovic.customer.netspace.net.au/xr6/IMG_1537.JPG
  • Xtreme Xalted Member
  • Member For: 21y 10m 6d
Cut them JB.
The bump stops should be a last resort for suspension travel.
The characteristics of the shockie and a lump of rubber are chalk and cheese. The shockie needs to have free travel to do its work.
If you were to have a couple of passengers in the back on a less than perfect road, they would end up with compacted spines.
Been down that road before.
  • Great rack
  • Member For: 21y 11m 14d
Cut them JB.
The "bump stop", is there to help the SPRING, not the SHOCK ABSORBER
......totally diferent concept. :spoton:
