Guest PSIXR6 Guests Posted 17/03/05 10:42 AM Share Posted 17/03/05 10:42 AM Just curious to see what sort of times you guys are running with say 250rwkw. Also the difference between manual and auto.Is 13 flat out the question in a 5speed???~al Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/ Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 15d Gender: Male Location: Strapped in and holding on Posted 17/03/05 11:10 AM Share Posted 17/03/05 11:10 AM PSIXR6 said: Just curious to see what sort of times you guys are running with say 250rwkw. Also the difference between manual and auto.Is 13 flat out the question in a 5speed???~al<{POST_SNAPBACK}>yes Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232657 Share on other sites More sharing options...
TBO240 Member 628 Member For: 21y 8m 25d Gender: Male Location: Geelong Posted 17/03/05 11:49 AM Share Posted 17/03/05 11:49 AM as below +0.40 for manual Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232677 Share on other sites More sharing options...
maximum_velocity Lemming No #5 Member 1,991 Member For: 20y 5m 7d Gender: Male Location: Endeavour Hills, Victoria Posted 17/03/05 12:16 PM Share Posted 17/03/05 12:16 PM I was gonna say about 13.5 with a terminal speed of maybe around 105-108 somewhere around there. Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232687 Share on other sites More sharing options...
shiftyxr Member 340 Member For: 21y 8d Location: Adelaide Posted 17/03/05 12:30 PM Share Posted 17/03/05 12:30 PM I ran 12.9 with 269kw auto Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232693 Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 10m 8d Location: D SHIRE! Posted 17/03/05 11:25 PM Share Posted 17/03/05 11:25 PM (edited) shiftyxr said: I ran 12.9 with 269kw auto<{POST_SNAPBACK}>that's a good time shifty,what was your 60ft and is that Edit plus injectorsCYA JEFF Edited 20/03/05 10:28 PM by ms700 Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232753 Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 5m 4d Location: Eastern Suburbs of Mexico Posted 17/03/05 11:33 PM Share Posted 17/03/05 11:33 PM PSIXR6 said: Just curious to see what sort of times you guys are running with say 250rwkw. Also the difference between manual and auto.Is 13 flat out the question in a 5speed???~alAllen with a reasonable 60ft (2.1) in a T5 if you can minimise killing your clutch you will be looking at a low 13 at around 106-107 mph.Happy to give you some advice, if you come down to calder and give it a go!!! Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232754 Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 11m 19d Gender: Male Location: At the lights, waiting for you. Posted 18/03/05 02:07 AM Share Posted 18/03/05 02:07 AM I'm guessing 13.1 106mph. Let the car cool way down before you run and the first run will be your best so don't waste itGeea. Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232800 Share on other sites More sharing options...
ch0pper Member 204 Member For: 20y 2m 19d Location: S/W Sydney Posted 18/03/05 09:46 AM Share Posted 18/03/05 09:46 AM I will guess a 13.3 et I run a 13.3 recently with 242rwkw in an auto, so given you have 10rwkw more than mine but in a manual, you should run similar I would say..Good luck m8 Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232955 Share on other sites More sharing options...
CHIPS Great rack Donating Members 1,351 Member For: 22y 1m 5d Gender: Male Location: Geelong Vic. Posted 18/03/05 10:07 AM Share Posted 18/03/05 10:07 AM Geeseman said: xr6ikness said: shiftyxr said: I ran 12.9 with 269kw autothat's a good time shifty,what was your 60ft and is that Edit plus injectorsCYA JEFF Deleted by ms700 Link to comment https://www.fordxr6turbo.com/forum/topic/16416-what-sort-of-times-on-the-14/#findComment-232962 Share on other sites More sharing options...
