Street Tuner Member 727 Member For: 22y 4m 5d Posted 13/03/05 06:14 AM Share Posted 13/03/05 06:14 AM I believe the 'F' setting is only ever 'filled' once, unless you have the box cleared by your dealer. Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-230920 Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 21y 5d Gender: Male Location: claremont meadows, sydney Posted 13/03/05 06:18 AM Author Share Posted 13/03/05 06:18 AM so if I have if flashed by ford and then return to 10psi tune and a little down the track return to ford with the factory tune they will see that I dont have an updated flash but on the books it will say I have hmmmthat defeat it as being stealth how do I tell ford not to flash me Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-230923 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 11m 2d Location: Mildura Posted 13/03/05 07:47 AM Share Posted 13/03/05 07:47 AM Simple solution,If your car is running perfectly why take it to a Ford dealer to get the car serviced. Get the car serviced by the place you purchased your Flasher, they are most likely car tuners and they carry out servicing as well. That way the only software updates will be from CAPA.As long as you use appropriate standard oils etc and or Ford genuine parts there should be no worries about warranty.macka Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-230959 Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 21y 5d Gender: Male Location: claremont meadows, sydney Posted 13/03/05 08:50 AM Author Share Posted 13/03/05 08:50 AM (edited) I have issues with limp mode so I need to take it to fordas for taking it to where I got the edit ..bit far to travell to capa from sydney Edited 13/03/05 08:51 AM by xrturb Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-230987 Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 6m 3d Location: Sydney Posted 13/03/05 09:04 AM Share Posted 13/03/05 09:04 AM xrturb said: I have issues with limp mode so I need to take it to fordas for taking it to where I got the edit ..bit far to travell to capa from sydneyInteresting. Does you car still suffer from limp mode even after the install of edit?thanks Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-230994 Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 21y 5d Gender: Male Location: claremont meadows, sydney Posted 13/03/05 09:09 AM Author Share Posted 13/03/05 09:09 AM (edited) no I have alwaysed had it GMtalking to a service guy ,seem to think it is an issue with the throtle bodyit is not a software problem Edited 13/03/05 09:10 AM by xrturb Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-230999 Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 6m 3d Location: Sydney Posted 13/03/05 09:10 AM Share Posted 13/03/05 09:10 AM Ok so when does it happen for you?I was under the impression that edit fixed this problem as it eliminated the signal responsible for sending the car into limp mode??? Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-231001 Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 21y 5d Gender: Male Location: claremont meadows, sydney Posted 13/03/05 09:15 AM Author Share Posted 13/03/05 09:15 AM it does it all over the place ..happened once on start up ..then once 3 times in a row done it once this weekas for edit fixing the problem ...wel its not software ..like I said there is a problem with the TB cant see how edit will over riding this error if I have an error the last thing I would like is edit over riding it Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-231003 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 4m 5d Posted 13/03/05 09:18 AM Share Posted 13/03/05 09:18 AM While the Flash software is incredible in its functionality Geeseman, we still arent at the point where we can command it to fix physically broken throttle bodies. Maybe in two weeks. Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-231004 Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 6m 3d Location: Sydney Posted 13/03/05 09:19 AM Share Posted 13/03/05 09:19 AM Street Tuner said: While the Flash software is incredible in its functionality Geeseman, we still arent at the point where we can command it to fix physically broken throttle bodies. Maybe in two weeks.Haha very funny. I assumed this limp mode problem was that of the overboost limp mode issue. Obviously it isnt Link to comment https://www.fordxr6turbo.com/forum/topic/16253-capa-edit-tech/page/7/#findComment-231005 Share on other sites More sharing options...
