  • Member For: 22y 4m 5d
  jordak said:
Martin,
Could you please let us know  whats the latest with finding a solution for the surging / boost control issues being experienced by the majority of custom tuned cars ?
Cheers
Steve
<{POST_SNAPBACK}>
In fact only some of the generic tune cars show this problem. Most custom tunes are able to eliminate any issues with the boost control system.
Watch for some revisions to the boost tuning process over the next fortnight, in an attemp to make the process simpler
  • Replies 169
  boomer01 said:
Hi Martin,
FYI...RE the boost control issues, I've just fitted the Di Filippo 3.5" turbo back exhaust and the tuner here in Perth was unable to provide a useable custom tune after the exhaust mods (not having a go at the tuner, they gave it a good crack).  He mentioned boost was spiking and was unable to control it.
So much so I have re-applied the factory tune until a solution is found.  Guess I'm just re-iterating Steve's sentiments.  Any info would be greatly appreciated.
Regards,
Tom.
<{POST_SNAPBACK}>
I do believe that part of this problem is caused by the attack rate being requested. I.e. you want 11psi @ 2800rpm. Attempting to control the wastegate in such an aggressive manner will lead to control problems with overboost of the target figure. Let me explain.
Consider the system like an oscillating spring, where the software is the shock absorber. The first time the spring hits a bump (or the boost comes on in the engine) the shock absorber does its best to control the system from 'bouncing' (boost wandering either side of aim). The bigger the 'bump' (or the more desired boost you aim for at low rpm) the harder it is for the shocker to effectively dampen (for boost to be accurately controlled).
The solution in this instance is to reduce the 'bump' or bring the desired boost on in a more gentle fashion to allow complete control. This was suggested, and tried at the time your car was on the dyno with some success, but the tuner didn't want to compromise the 10 - 15kw that bringing the boost on sharply would deliver.
  mercurysteve said:
Under hard excelerating, it starts to make a strange noise toward the back of the car, possibly from the exhaust and surges a bit but does not cut out completely. IS IT OVERBOOSTING? What else might it be? I have not been game enough to push her hard to find out any more symptons. :blink:
<{POST_SNAPBACK}>
These sorts of problems cant be fixed by a crystal ball approach. Take it to an authorised tuner. There are several in your locale - Nizpro, HPF, Herrods etc. and have the plugs gapped, fuel delivery tested etc.
  Geeseman said:
Given one of the mods deleted heaps of post on the matter in another section of the forum, I'd Like to see some Dyno sheets with before and after runs featuring AFR, Boost, torque and power graphs that show Edit's  advantages over piggybacks please :blink:
<{POST_SNAPBACK}>
All good questions Geese. However we have covered this ground in some detail. I for one will be too busy answering the genuine questions in here to get tangled up in the argument of how a chinese made box of resistors and capacitors compares to a genuine PCM Editing tool.
If you need any more convincing remember.....Nizpro....130.9mph.....
  • Member For: 21y 6m 2d
Where have they been convered in detail? I havent seen any dyno graphs other than ones which show the edit with more power due to increased boost. I'd like to see same boost, same AFR with better torque and power curves under edit.
I think a lot of piggyback owners would like to see this as changing to edit is an expensive exercise especially if it yeilds no power gains other than those achieved with more boost.
  Street Tuner said:
Thankfully this hasnt proven to be the case.
As one example I do believe JB made more power at less boost swapping to the Edit. There is a thread here on it.
Well it hasn't been proven yet. JB is yet to produce any boost vs power graphs.
Surely as the head tuner for cappa you would have some proof on hand of the edit's superiority over piggybacks with a customer's conversion?
  • god bless my kids
  • Member For: 21y 4d
martin
can you please list the other things that can be changed through a custom tune other that's in the box
like keeping boost up between gears on a manual ect
