Mobile Phone Presenter
AzZaMaTaZ
  • Replies 23
Posted Images
  • Member For: 21y 11m 4d
I have one, & I think it's ok. You have to get used to it, & be carefull not the hit it if you reach across the car, as it is a little flimsy. You can fold it away inside the console, and with it out, you can still change gears without any problems (on the SSS auto). The position where it is, gives a good view of the phone & it's easy to answer / make a call when you need to. The presenter when folded out sits on the plastic cup holder surround & usually will mark the plastic, but if you put some foam tape under the phone holder, then it doesn't scratch into the plasic.
  • Seriously Flukey Member
  • Member For: 21y 20d
  AzZaMaTaZ said:
Is it good? how does it work? does it fold into the centre console?
Plz Explain
I was going to get a phone presenter but discovered it is a bit harder to use the SSS in manual mode so decided against. There is another fixing point beside the ICC which works well. :crybaby:
  GlennXR6T said:
They'd be a pain in the ass because they'd take up all the space in your centre console.
That too.
  • Member For: 21y 2m 21d
I`ve got one I think its more a bother to your passenger as it infringes a bit on their space especially if they a little on the heavy side.But as a rep on the road I think its pretty good.I don`t have any probs in sss mode at all.
  • Yes I am too tall for my hair
  • Member For: 20y 6m 9d
  flukeyluke said:
Plz Explain
<{POST_SNAPBACK}>
I was going to get a phone presenter but discovered it is a bit harder to use the SSS in manual mode so decided against. There is another fixing point beside the ICC which works well. :ermm:
<{POST_SNAPBACK}>
There is :o
pics please :ermm:
  • Team Blueprint
  • Member For: 21y 4m 23d
There crap...... they keep getting in the way... if I can find mine you can buy it for a few bucks........
I will look tonite
cheers
  • Crusty aviator
  • Member For: 20y 9m 22d
It does the job but is not very robust and requires you to move your line of vision well away from the road when using it. Something further forward in the vicinty of the centre console would be safer and live longer. That said I am used to mine and accept the lack of research that went into its design. It would be nice to have the AAC/MP3 files on my phone's (Nokia 6230) internal MMC memory playable through the in-car connection - which effectively splices the phone into the car sound system. Any suggestions there would be welcome. And before some bright spark suggests it, yes I have the MP3 input connector to the ICC but that is not compatible with the phone.
Dingah
  • Flower Power
  • Member For: 22y 6m
  fraggle said:
  flukeyluke said:
Plz Explain
<{POST_SNAPBACK}>
I was going to get a phone presenter but discovered it is a bit harder to use the SSS in manual mode so decided against. There is another fixing point beside the ICC which works well. :blush:
<{POST_SNAPBACK}>
There is :o
pics please :blush:
<{POST_SNAPBACK}>
I can't remember who took this pic, but here it is:
