  • Member For: 20y 5m 6d
Sure Simon. Will organise it this afternoon. Which graphs exactly do you want? AFR? Boost? Tractive effort? How about all three?
Will be good for you to host the dyno runs for the tune you did on my car, namely, boost and AFR just to ensure we can do a fair comparison. I only have the tractive effort & rwkw graph.
Who can host the pics for me or how can I do it?
  • Replies 28
Posted Images
  • Wanabe mechanical engineer
  • Member For: 20y 8m 24d
All 3.
In the reply screen, go down to below the smilies and it says 'file attachments'.
You simply press browse, find the file on your computer, and then 'add this attachment'.
Do this several times to add all your pictures to the one post, before pressing 'add reply'.
  • - Track Bound EVO III -
  • Member For: 20y 5m 26d
<{POST_SNAPBACK}>
From your reply, I am 'assuming' you had your car tuned by GTP-330, then got inj's and took it to D&T. Is that correct?
Were the dyno runs made on the same make of dyno?
Ta..
Ta..
<{POST_SNAPBACK}>
I purchased the bigger pump and injectors in Jan, about a month before I got the car.
Yes, Simon did the initial tune on my car. As D & T's workshop is literally a 5 minute walk from my workshop it was more convenient for me to take the car their, rather than commute 40 plus minutes to Simon's place. It's not a reflection on Simon's tuning ability that I took the car elsewhere, rather geography.
See attached dyno sheets to answer your second question.
post-5969-1110263479_thumb.jpgpost-5969-1110263550_thumb.jpgpost-5969-1110263672_thumb.jpgpost-5969-1110263744_thumb.jpg
Looking at the boost dyno sheet it is apparent that peak power is made with 10psi, not 8.8 or 9 psi as I initially thought. Therefore the car has made a little more power with the bigger injectors running the same boost as the prior tune, but imo the power difference is negligable. Power difference could be attributed to atmospheric conditions.
It's the fact the AFR's are at a good point which makes me more confident getting 'up' the car with the bigger injectors rather than the stock ones.
Well done guys you are getting close to me now I think I will have the stage 3 aps
done in the next 3 weeks I can not wait.
Is there anyone out there with some cheap sp9000 I need new rear tyres at only 6000ks lol :spoton:
  GTP-330 said:
Care to post the new dyno graph for us to see?
<{POST_SNAPBACK}>
Done :ermm:
Care to post the dyno sheets of the F6 running 13 psi? Would be interesting to see just how much power the stock injectors can support. Also, is the F6 running 13 psi totally stock?
  • Team Xtreme
  • Member For: 20y 4m 2d
  M6 XR6T said:
Done :blush:
I owuld if I could get the cars back froim ford , they are both in awaiting clutch fixes. But dont worry mate, ill post them soon enough. But not on here, ill get Pmed again and told off as im not a forum sponsor
Is there anyone out there with some cheap sp9000 I need new rear tyres at only 6000ks lol :blush:
<{POST_SNAPBACK}>
Crazy, could you tell us wots in stage 2 and 3??
Thanks.
If u can't that's understandable..
